removing coolant pipe
Old Apr 25, 2007 | 11:19 AM
wmertz187's Avatar
Default removing coolant pipe
How is the coolant pipe removed from the back of the block?
Old Apr 25, 2007 | 12:38 PM
IN VTEC's Avatar
Default Re: removing coolant pipe (wmertz187)
Remove the lower radiator hose from the thermostat housing, unbolt the thermostat housing, pull thermostat housing off of coolant pipe, and lastly pull the coolant pipe from the block.
In some motors, you have to remove the oil cooler and knock sensor to give you room to wiggle.
:jdmshmaydm:
Jan 12, 2015 03:20 PM
Mishako129
Apr 11, 2013 05:01 PM
shocker911
Mar 6, 2013 02:17 AM
NZstan
Apr 16, 2010 09:15 PM
