reground cam
Old Jul 7, 2003 | 08:28 AM
chictunner97ex's Avatar
Default reground cam
what effect does a reground cam have on the crank timing, if any. and if there are any what adjustments do you make when installing a ported and polished head with the cam reground?
Old Jul 7, 2003 | 10:42 AM
altoid's Avatar
Default Re: reground cam (chictunner97ex)
usually regrounds get their base circle ground away to increase duration, though the power is nice it usually leads to premature rocker arm and or valve failure of some sort because the velocity in which the rocker arm goes up and down is increased like mad. Im not sure how long it takes on a honda, I went about 6-9 thousand miles with mine and didn't have any problems, i plan to go back to it but not right now. ohh and no affects on the timing and no adjustments when installing the head, just the standard valve adjustment
neofreak
25
Jan 1, 2007 12:33 PM
Bevin
Sep 19, 2006 11:01 PM
Takumi Fujiwara
Jan 18, 2006 09:49 PM
TylerH
Nov 18, 2004 07:12 PM
toooslow
Jun 10, 2003 03:15 PM
