reducing power steering?
Old Dec 8, 2003 | 01:37 AM
azian21485's Avatar
Default reducing power steering?
is there a way to reduce the amount power steering helps you turn the wheel without removing it completely?
Old Dec 8, 2003 | 06:18 AM
Daemione's Avatar
Default Re: reducing power steering? (azian21485)
wider/stickier tires . . . .
Just an idea, but you could try replacing the hoses at the pump with ones of smaller diameter, or maybe some kind of restrictor. Although that may hurt power & pump life, since it will have to work harder.
Old Dec 8, 2003 | 06:28 AM
Muckman's Avatar
Moderator in Chief
Different size pulleys?
Old Dec 8, 2003 | 07:48 AM
2000SS's Avatar
Try a bigger pulley, you will also need a larger belt depending on the size of the pulley.
J_Marc
Dec 29, 2008 09:44 PM
yahright
Apr 24, 2004 07:00 AM
UncleBen'sRacing
19
Feb 3, 2003 11:10 PM
