rebuilt engine....how can i keep it lubed while its sitting
Old Aug 7, 2003 | 06:08 PM
VTgringo's Avatar
Default rebuilt engine....how can i keep it lubed while its sitting
can someone tell me what i should spray/put in the engine while its waiting to installed. It has been freshly rebuilt and i don't want to chance anything when i put it in. thanks guys
Old Aug 7, 2003 | 06:35 PM
VTgringo's Avatar
Default Re: rebuilt engine....how can i keep it lubed while its sitting (VTgringo)
help
Old Aug 7, 2003 | 06:54 PM
GumballNA's Avatar
How long is ur waiting period? and is it all re-assembled...?? if it is.. just leave it be.. it will be just fine! as long as it is not running, it will be just fine.
Old Aug 7, 2003 | 06:56 PM
quik1's Avatar
Usually when you build a motor you spray wd-40 on the cylinder walls and assembly lube every thing else so that should be good. Did you build it or did you get it done somewhere?
HONDADNA's Avatar
do you have ductile steel sleeves? but you should cover it with plastic to keep dust and other things. but, if you have a ductile sleeve spray wd40 or coat the walls with 10w 30 oil.
Old Aug 7, 2003 | 07:07 PM
VTgringo's Avatar
Default Re: rebuilt engine....how can i keep it lubed while its sitting (HONDADNA)
stock sleeves....i am assuming they are steel.......thanks for the help everyone
Reza^
May 22, 2007 10:24 AM
spork motorsports
14
Apr 24, 2007 07:39 AM
killerpenguin21
Aug 5, 2006 11:42 PM
teg your it
May 22, 2006 07:59 PM
gaydm.accord
Dec 10, 2003 12:13 PM
