Rebuilt B16 smoking... Help
so is there any way to tell for sure weather it is the valve seals and not the rings, i did a compression dry check and all is well, should i do a wet compression test too...
is it possible to change the valve stem seals with out taking the head off?
Yes. Use compressed air with a spark plug fitting to keep the valves up or use some nylon rope through the hole to keep the valves from falling into the cly.
Redprelude98
Nov 25, 2008 10:42 AM
