rebuilding ls motor
Old Feb 24, 2006 | 01:39 PM
Panoply's Avatar
Default rebuilding ls motor
hey guys, sorry im sure this question is been asked several hundred times, but i wasn't quite sure what to search under to find out exactly what i want.
basically i was given an ls motor that had a bad rod bearing. i want this motor to be something i learn on. ive read jeff evans gsr build and understand exactly what he's doing so i think thats a good start.
first things first, i want to do a total rebuild starting with the bottom end. not necessarily wanting to go with the most expensive setup. mostly oem stuff just to get the car running well and strong.
so since the bottom end on this motor had a knocking rod could i assume that the crank will be trash? can i get the crank balanced to fix it? is there anything i can do to see if the crank is trashed itself? i have a few different sets of micrometers, however im not sure if this is the proper instrument to determine if the crank is still good. if the crank was no good. could i also assume that the rods would be bad? im really hoping that i can still use the crank, rods and pistons... would this be a crazy idea to think that i could reuse these parts? do pistons have any type of wear where basically after so many miles you are going to want to get rid of them and go for new? is there a good way to inspect the ringlands?
like i said, im just trying to learn. if you know of a good write up, specifically on b18b's, that would be of great help. thanks to whoever can lend a hand.
Old Feb 24, 2006 | 04:24 PM
LSVTEC 91 Civic's Avatar
Banned
I posted in your OTHER thread.
Old Feb 27, 2006 | 07:26 AM
Panoply's Avatar
Default Re: (LSVT3K 91 C1V1C)
thanks
tdrewd
Sep 28, 2012 10:17 AM
.Grimace
Mar 10, 2008 09:53 PM
typer2k1
Dec 14, 2006 10:43 PM
Panoply
Feb 27, 2006 07:28 AM
vadersi
Oct 23, 2004 01:23 PM
