Rear upper control arm, dc2 help
Old Jul 28, 2004 | 12:18 PM
  #26
Bseriescivic5's Avatar
Default Re: (boostedsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsol &raquo;</TD></TR><TR><TD CLASS="quote">
You're right, it's not the strongest material in the world, but it should help in my case to hold the bolt in from the other side until i am able to secure the nut to the other side.
I would by no means try to JB the upper control arm to the frame.</TD></TR></TABLE>
so how accesable is the other side of the frame, i know its hollow, but is it possible for 2 people to complete the job ?/??/ and just an update, the guy who is working on my car is going to use helicoil on it...........so i guess i wasted my money for him to do som,ething that i can.
Old Jul 28, 2004 | 01:05 PM
  #27
boostedsol's Avatar
Default Re: (Bseriescivic5)
It is possible, it's just going to be time consuming and a pain in the *** to do. But, in my situation im going to have to do it this way.
I wish mine wasn't as fucked up so I could use helicoil. How much is this guy going to charge you, you should find out and if it's expensive i'd recomend getting your car back and doing it yourself.
Old Jul 28, 2004 | 01:26 PM
  #28
prolly like 100bucks im not sure, i dopnt know how to install a helicoil, my threads are all crossed and fucked up too.
Old Aug 1, 2004 | 12:34 PM
  #29
Can anyone tell me the foreseeable conseqences of driving the car under this condition, no upper control arm bolts.... i mean it still has 4 other bolts, holding it in place.....time is running out and i need to get the car back to complete the swap, let me know what you guys think.
Old Aug 2, 2004 | 07:04 AM
  #30
anyone?
Old Aug 2, 2004 | 08:55 AM
  #31
boostedsol's Avatar
haha, I've though about that too, but it's just not a good idea. I would just get it fixed. What ever happened to that guy that was going to fix it for you?
Old Aug 2, 2004 | 09:02 AM
  #32
hes taking FOREVER.........really starting to **** me off and hes ******* up my schedual, swap was soppose to be in the past weekend.........so i was thinking about just getting the car back and driving on it.
Old Aug 4, 2004 | 05:31 AM
  #33
job is done, guy did a real good job, used helicoil and grade 8 bolts worked out real nice, charged me 50 bucks...not bad price, but he did make me wait a while.......
Old Sep 15, 2004 | 08:23 PM
  #34
boostedsol's Avatar
SEpt 15, 2004 and my car is finally finished. I had to drop the gas tank and drill out the upper control arm holes. Then I put the bolts through and secured the upper control arm. What a major pain in the ***! I'm just glad its done. amen
Old Sep 16, 2004 | 05:52 AM
  #35
SkinnyKinnee's Avatar
Default Re: Rear upper control arm, dc2 help (boostedsol)
The same problem happened to me when i was doing camber kits. I was able to drill out the hole and there was enough room behind it to thread a nut onto the bolt that came through. you obviously need a longer bolt than before. i havent had any problems.
Old Sep 16, 2004 | 02:18 PM
  #36
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsol &raquo;</TD></TR><TR><TD CLASS="quote">SEpt 15, 2004 and my car is finally finished. I had to drop the gas tank and drill out the upper control arm holes. Then I put the bolts through and secured the upper control arm. What a major pain in the ***! I'm just glad its done. amen </TD></TR></TABLE>
I havent been keeping up with this tread, but wow that sounds like it was alot of work, how long did it take you, any problems? hows it work out?
Old Sep 16, 2004 | 02:37 PM
  #37
boostedsol's Avatar
yeah, it was alot of work. I think the most time consuming and hardest part was draining my gas tank. I had a 3/4 full tank so that was a bitch to put up with all the fumes. At one point I thought I was going to pass out lol. Removing the tank was easy, after that I had barely enough room to stick the drill in and make the holes.
everything is holding up fine now, car is running good. This took me so long due to number of reasons... lack of tools/ lack of help/ waiting for help/ then saying f this im doing this myself.
shes all good now though
Old Sep 16, 2004 | 06:11 PM
  #38
yeah i know the feeling, my car is dead in the water right now, and im at college, not able to work on it.
Old Sep 17, 2004 | 01:18 AM
  #39
boostedsol's Avatar
damn.... I thought you got yours done already?
Old Sep 17, 2004 | 11:23 AM
  #40
no, the upper control arm is fixed via helicoil, but i just finished a b16 swap, and i couldnt get it to run before i had to leave so, i know your feeling.
MaXiMuS1701
Jun 29, 2007 10:12 PM
BG-Teg
Jun 3, 2007 06:54 PM
kyden
Suspension & Brakes
Jan 25, 2006 10:56 PM
Hyb
Feb 2, 2005 05:55 PM
