Rear anti roll bar
Old Sep 13, 2002 | 06:35 AM
gavhowe's Avatar
Default Rear anti roll bar
I know this has been covered but as i am from the Uk i want to makes sure. on a 94 civic EG5 i want to up grade the rear anti roll bar, it has been said that u can use a ITR one with few mods. is this a GSR one or Type R. As in the Uk we only have Type R Itr's will this one fit and work what dia is it.
Old Sep 13, 2002 | 07:07 AM
emr88's Avatar
Default Re: Rear anti roll bar (gavhowe)
Do a search for ITR sway bar , someone just posted the same question. If your car didn't come stock with a rear sway bar then in addition to a mounting kit you'll need to get
Integra endlink assemblies and Integra or Civic/del Sol LCA (rear sway compatible only).
This topic is pretty common. You'll need a way to mount the bar, either BSQ or Beaks. Do a search for those and you'll find a ton of info on them. Check out their websites
BSQ-http://www.geocities.com/bretq/mounting_kit.html
Beaks-http://www.beaksproducts.com/main.html
Also, I'm not sure on this but I believe the JDM ITR swaybar may be 23mm opposed to the 22mm for the USDM ITR. You can use the mounting kits above with either bar.
I just purchased a Beaks kit for my Integra but I haven't installed it yet. The quality of the parts look really good.
mish__
Suspension & Brakes
May 27, 2011 09:08 PM
meric0786
Suspension & Brakes
Apr 24, 2009 01:24 PM
dj theoretic
11
Jan 18, 2009 11:49 AM
gabspeed
Mar 17, 2004 04:39 AM
2000si
Feb 13, 2003 11:52 AM
