Random Turn Offs
Old Dec 23, 2005 | 07:36 PM
Mavrick's Avatar
Default Random Turn Offs
Anyone know what would cause my d15a3 87 crx si to suddenly turn its ignition off while driving? not all elec is lost i still have starter and radio but no dash lights. I have to keep trying the key until the red engine lights come on so i know its armed.
Old Dec 25, 2005 | 11:57 AM
Mavrick's Avatar
Default Re: Random Turn Offs (Mavrick)
anyone know?
Old Dec 25, 2005 | 01:28 PM
Chiovnidca's Avatar
Could be a bad ignition switch?
Old Dec 26, 2005 | 06:27 PM
Mavrick's Avatar
Default Re: Random Turn Offs (Chiovnidca)
i was hoping so, is that the only thing it could be?
Old Dec 26, 2005 | 06:38 PM
djtony5's Avatar
Check your battery terminal.
Old Dec 27, 2005 | 05:46 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Could be a bad ignition switch?</TD></TR></TABLE>I'll vote for this too. It can open the 'run' circuit, but still have power to the accessory circuit.
A bad battery terminal should affect everything, not just one circuit.
Another possibility is the main relay, depending on exactly what loses power. But since bad ignition switches are sorta common, check that first. Got a multi-meter?
Old Dec 27, 2005 | 10:43 AM
Mavrick's Avatar
Default Re: Random Turn Offs (JimBlake)
yes i do, how do i check?
Old Dec 27, 2005 | 01:17 PM
JimBlake's Avatar
Probably the switch is about the same on most Hondas. But I won't say wire colors because those are probably different for other years/models. First, get access to the back of the switch, where the wiring harness plugs into the electrical part of the ignition switch. You can probably put a meter probe in the back of that plug, so you can check without unplugging it.
There's one wire which provides power to the switch, it should be energized all the time. You'll see that by measuring +battery voltage when the switch is turned off. Red meter probe on that terminal, black on some nice metal ground.
Another wire becomes hot when you turn the key to 'accessory'. That one seems like it's not giving you trouble based on your first post.
Another wire becomes hot when you turn the key to 'ON'. This is the one you're worried about. Continue to check if it's energized, as you wiggle the key, or something. If it only screws up occassionally, you might have to figure out how to get a jumper wire in there. Then you can hook up the meter while driving, so you can watch for it to screw up.
The last wire is only hot while you hold the key at the 'start' position.
Old Dec 28, 2005 | 12:53 PM
Mavrick's Avatar
well it works because it gets continuity, the failure only happens sometimes. As for ohm specs, what am i looking for?
Tido831
Jul 10, 2018 09:39 AM
Tido831
Jul 6, 2018 05:45 AM
carnot
Jul 9, 2012 05:28 AM
91-lsvtecsi
Mar 4, 2012 02:47 PM
GhostBB6
Jan 13, 2006 04:47 AM
