Radiator seams split, why?
Old Feb 22, 2004 | 05:32 AM
Jack Black's Avatar
Default Radiator seams split, why?
94 LS w/ OEM-style radiator (aluminum core, plastic tanks). The tanks did not crack as one would expect. Instead, the seam where the tank is attached to the core split open. Seems like it would have to be some sort of excessive pressure situation to cause that kind of failure, right?
I flushed the system and replaced both the thermostat and water pump a little over a month ago. I have now replaced the radiator and cap, but obviously I don't want the radiator to fail again due to the same problem.
So the question is: what would cause excessive pressure to build up in the radiator? What should I check to make sure this doesn't happen again?
Old Feb 22, 2004 | 12:50 PM
onePOINTsix's Avatar
Default Re: Radiator seams split, why? (Agent Smith)
i'm not really sure why it happens but the exact same thing your talking about happened on my firend's 95 Intrgra GSR, replace it as soon as possible because the endtank eventually blew off as we were driving
edit: oh you already replaced it, one thing you can do to prevent it is to make sure your heat is not recurculating
Old Feb 22, 2004 | 01:09 PM
RCautoworks's Avatar
Maybe the cap was defective and would not open.
Old Feb 22, 2004 | 04:08 PM
h22 civic's Avatar
Default Re: Radiator seams split, why? (90blackcrx)
you have water in rad or anti-freeze???????? mite of froze if wasnt enough anti-freeze
Old Feb 23, 2004 | 07:52 AM
Jack Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the cap was defective and would not open.</TD></TR></TABLE>
That's the only thing I could think of, too. The cap looked fine, though, nothing obviously stuck together or anything like that. I talked to a mechanic this morning and he said the cap was about the only thing that would mess up the pressure. Guess I'll just keep an eye on it for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">you have water in rad or anti-freeze???????? mite of froze if wasnt enough anti-freeze</TD></TR></TABLE>
50/50. No, it definitely didn't freeze (see location).
Old Feb 23, 2004 | 07:50 PM
Sector9guy's Avatar
ive had a similar experience with my friend's jdm b16a w/ gsr rad. after driving for more than five minutes, his car would overheat and his radiator hose would blow off. turns out he dented his exhaust and it was creating excessive backpressure, got new piping and fixed the overheating prob. hope this helps in some way
Skeetzy
19
Nov 14, 2016 08:51 AM
inaety
Aug 4, 2011 04:15 PM
dwn2earth922
Sep 12, 2009 10:00 AM
Nocturnal
Dec 2, 2005 08:20 PM
projectM
17
Feb 14, 2003 12:53 AM
