.Radiator Fan doesn't turn on???
Old Apr 24, 2005 | 12:21 PM
solk1dd's Avatar
Default .Radiator Fan doesn't turn on???
I have a 94 integra GSR STOCK.
fan works i tested it but it doesnt turn on by itself??
Old Apr 24, 2005 | 03:01 PM
zman's Avatar
Default Re: .Radiator Fan doesn't turn on??? (solk1dd)
had the same problem....it was my thermoswitch (fan switch) its the sensor in the thermostat housing....cost like $50 for a new one from honda up here in canada.
To confirm that this is your problem try jumping the thermoswitch, do this by putting a piece of wire or a paper clip in the plug jumping it or completing the circuit. If the fan turns on when you start the car with the thermoswitch jumped then its safe to say that this is the problem.
Old Apr 24, 2005 | 05:29 PM
D-tuned's Avatar
Default Re: .Radiator Fan doesn't turn on??? (zman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zman &raquo;</TD></TR><TR><TD CLASS="quote">had the same problem....it was my thermoswitch (fan switch) its the sensor in the thermostat housing....cost like $50 for a new one from honda up here in canada.
To confirm that this is your problem try jumping the thermoswitch, do this by putting a piece of wire or a paper clip in the plug jumping it or completing the circuit. If the fan turns on when you start the car with the thermoswitch jumped then its safe to say that this is the problem.</TD></TR></TABLE>
Old Apr 24, 2005 | 09:58 PM
ORcivicsi's Avatar
Default Re: .Radiator Fan doesn't turn on??? (2000civicsi)
If you need one after testing. I just bought one for my si. And i never used it. Hit me up if you need it. CHEAP
Old May 4, 2005 | 01:36 PM
killer6993's Avatar
Default Re: .Radiator Fan doesn't turn on??? (ORcivicsi)
Does anyone have a link to this part? I need to buy one and dunno if I'm looking for the right part.
Old May 4, 2005 | 03:33 PM
NJIN BUILDR's Avatar
Default Re: .Radiator Fan doesn't turn on??? (killer6993)
http://www.acuraparts247.com/s...ch=no
Culinarydolly
Sep 6, 2014 12:04 AM
joelro28
Feb 22, 2014 12:43 PM
maverick32
Jun 17, 2009 10:49 PM
Whatever
Apr 23, 2009 09:49 AM
kpop
Jun 13, 2006 08:24 AM
