rack and pinion replacement
Old Apr 25, 2011 | 12:06 AM
Xxcivic99xX's Avatar
Default rack and pinion replacement
my 99 civic just got its R&P replaced at a shop. The shop used a rebuilt/remanufactured R&P, the ends of the dust boots are held by ring clips. Tonight when adjusting my coilovers, I seen the rings were coming off slightly so I grabbed a pair or needle nose pliers and tighten them back on. If this happens again, will tie straps be good enough? and how tight does it have to be? and where exactly does the boot sit when I do this?
Old Apr 25, 2011 | 01:02 AM
blackedEk's Avatar
Default Re: rack and pinion replacement
set it back to where it was originally, and you can buy those adjustable hose clamps, there good and wont come off. You can find em at any local parts store. don't over tighten them since its going on over the boot, but make sure its a nice firm tight fit.
I wouldn't use those tie straps for this, in your situation.
Old Apr 25, 2011 | 04:43 AM
wc4ohio's Avatar
If you're talking about the bellows boots covering the inner tie rods, you can use zip ties without issue. A lot of shops use them instead of clamps, and I use them too.
Old Apr 25, 2011 | 09:34 AM
alright, thank you guys for the info
Old Apr 25, 2011 | 06:09 PM
fcm's Avatar
fcm
Old Fart
If it is #8 your talking about... http://www.hondaautomotiveparts.com/...=P.S.+GEAR+BOX use hose clamps, or HD wire ties, but hose clamps work best. 94
dfJDM
25
Dec 26, 2010 04:28 AM
TweedZ
Feb 19, 2009 09:10 AM
msinsky14
Apr 16, 2007 11:03 AM
shortlid
Apr 4, 2007 10:28 AM
Urban Business
Apr 16, 2003 04:39 PM
