RACE GAS ???
hello there guys my friends cousin works at the airport he can get us free jet fuel
i have a few qustions
1. will it effect the O2 sensor.
2.will it rot fuel lines, rubber gaskets or fuel injectors
3.can i run it all the time
4.what is the up side to using the aivation gas
5.what kind of power gains will i get from it
6. is this a better gas for NOS
7.will the car run leaner on htis gas
my setup
B18c5,header, no KAT, DC sports full exauste, Crower stage 2 cams, springs and retainers, VAFC, chipped ECU, MSD dig6
thanks for all your help
my setup
Unless you have very high compression, Av gas is of zero use for you.
I hope it is Av gas you are referring to, as your car will not run on jet fuel, which is a refined kerosine.
so i you guys were to get it for free would you use it in your car and it is avaition gas not jet fuel sorry
and with a 12 to 1 compression motor it would be a good idea
and for nos setups will this stuff fu(k up your O2 sensors
well if you can get it for free, talk up. the 12:1 and laughin gas will LOVE it. and while you're at it... tank up some 5 gallon cans and sell it @ to all your buddies. what octane is it?
ok now that there is a deference would you run avation in your car all the time if it were free amd if so would you run it stright or mix it, if so what ratio would you mix it?
