A quick Synchromesh question
Old Mar 23, 2006 | 04:44 AM
freakin's Avatar
Default A quick Synchromesh question
I went through what I could find on this site, but I'm still a little confused as to which fluid to run. I'm putting in 2 trannys over the next couple of weeks and want to use synchromesh in both. One is a S1 non-lsd and the other is a YS1 lsd tranny. What I've gather is that I should use the friction modified stuff for the LSD, but the regular stuff in the S1. Is that correct? Also, no one in town sells the FM version, so I have to go to a Mitsubishi dealer to buy a friction modifer additive (or at least I've been told to do so).
My plan was to buy 5 bottles of regular synchromesh to split between the two trannys and 1 bottle of the FM additive to put in the lsd tranny.
Do this sound right? Please correct me if I'm wrong. I'd rather be made to look like a fool on here than have a tranny blow up on me.
Old Mar 23, 2006 | 05:23 AM
Ron Carroll's Avatar
Default Re: A quick Synchromesh question (freakin)
It depends on what type of lsd you have if you need to add friction modifiers.
Old Mar 23, 2006 | 06:48 AM
gents97civ's Avatar
You only need the fm if it is a clutch type lsd. If it is oem honda lsd it is a gear type and does not require a friction modifier. Ps if you didnt know syncromesh is the same if you buy it in the penzoil bottle.
Old Mar 23, 2006 | 04:02 PM
freakin's Avatar
The LSD is OEM, so I'm assuming it's a gear type LSD. So from the sounds of it, I don't need the friction modifier for either. I'll try the parts stores for the Penzoil stuff (thanks for the tip), then head over to a GM dealer if I can't find it.
Old Mar 23, 2006 | 06:55 PM
Jmunk's Avatar
Autozone usually has the pennzoil stuff.
Old Mar 23, 2006 | 08:50 PM
Tad's Avatar
Tad
Default Re: (Jmunk)
i use the penzoil stuff in my sohc tranny..
but anyways, if you're ever confused about wut to run,
just screw all the hype about getting "the hot ****" and whatnot.
just get OEM for your application! you're garaunteed good results.
simple as that.
woolfgang
Jan 4, 2007 01:48 PM
spurge
Mar 2, 2006 01:47 PM
bmrgold
Sep 16, 2004 03:43 PM
CRXB16aJDM
19
Dec 14, 2002 05:57 AM
charjacq
14
Dec 10, 2002 07:57 PM
