Quick question about compression!
Old Dec 27, 2003 | 12:19 AM
^jefs0ng's Avatar
Banned
Default Quick question about compression!
Okay so bad valves has caused some horrible compression #s. So low that one cylinder isn't even firing. I must admit my car still hauls *** for a 3 cylinder. ANYWAY I came across some oem b16a2 valves. Now my question is, should I be getting the valve springs and retainers? Is there any chance mine would be bad from my valves? I mean it's not that much of a deal since it's all fairly cheap and I can go check them out.. input please? I'm just jobless and poor so I'd like to save every penny possible. But if it's "safer" or recomended to replace the whole valvetrain I will.. thanks!
Old Dec 27, 2003 | 06:58 AM
fulldragcrx's Avatar
Default Re: Quick question about compression! (.jefs0ng)
What testing have you done to make sure its your valves.
if it is why did the valves go bad?
what engine are we talking about ?
Old Dec 27, 2003 | 07:51 AM
LudeyKrus's Avatar
Yes, how did you figure it was the valves?
If it's FOR SURE the valves, then no, you just replace the valves. Unless you're building this for some high revving and it's a high mileage head, there should be no prob w/ the springs and retainers.
Old Dec 27, 2003 | 11:08 AM
^jefs0ng's Avatar
Banned
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Yes, how did you figure it was the valves?
If it's FOR SURE the valves, then no, you just replace the valves. Unless you're building this for some high revving and it's a high mileage head, there should be no prob w/ the springs and retainers.</TD></TR></TABLE>
awesome I know it's the valves, cause we did the whole oil thing to check if it was my rings.
Old Dec 27, 2003 | 11:34 AM
smokey2.0's Avatar
Default Re: (.jefs0ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">
awesome I know it's the valves, cause we did the whole oil thing to check if it was my rings.</TD></TR></TABLE>
that's what i thought, but on mine it was the valve adjustment that was giving me problems!
Old Dec 27, 2003 | 11:58 AM
quik1's Avatar
Default Re: (smokey2.0)
I would check the valve adjustment first then follow it up with a leakdown to determine which valve it is.
Old Dec 27, 2003 | 12:09 PM
^jefs0ng's Avatar
Banned
Default Re: (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">I would check the valve adjustment first then follow it up with a leakdown to determine which valve it is.</TD></TR></TABLE>
at ~30 bucks a set, I'm willing to replace all of them.. And I just got a valve adjustment no more than a month ago. Anything else I should do to "ensure" that it's my valves?
Old Dec 27, 2003 | 12:16 PM
quik1's Avatar
30 bucks for a set of valves or valve seals that seems low for a set of valves.
Old Dec 27, 2003 | 01:12 PM
^jefs0ng's Avatar
Banned
Default Re: (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">30 bucks for a set of valves or valve seals that seems low for a set of valves.</TD></TR></TABLE>
43 for brand new valve seals + 25 for intake valves [not new].. so it's 78 bucks... still considering if I should replace the exhaust ones.. should.. I?
Old Dec 27, 2003 | 01:24 PM
quik1's Avatar
If there still fine I wouldn't even if I wasn't on a budget i'd just change the seals and your valve springs will be fine. Good luck.
Old Dec 27, 2003 | 06:21 PM
Default Re: (quik1)
if ya got any money left over, throw it my way, i sure could use it.
Alot of poeple just throwing money at a car lately, and alot of them are poor now with no car.
Anyone catching my drift?
Old Dec 28, 2003 | 02:50 PM
^jefs0ng's Avatar
Banned
Default Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">if ya got any money left over, throw it my way, i sure could use it.
Anyone catching my drift?</TD></TR></TABLE>
oh don't worry I don't have extra money, and if I did there people I'd rather give it to instead of some guy I've never met.
B20Wannabe
Nov 21, 2012 08:30 AM
h46it
Jun 2, 2002 09:36 PM
