quick Q about raising your redline
Old Jan 28, 2003 | 04:47 PM
yaya's Avatar
Default quick Q about raising your redline
a stock b18b redlines at 8900 right? anyway the torque usually drops about 700 before redline dramatically right?
so if you use a chipped ecu that raises the fuel curve and you raise the redline to lets say 9500 is the torque drop off still at ~8200?
i dont get the point of raising a rev limit on a stock fuel map
someone slap some sense into this f00
thanks
Old Jan 28, 2003 | 05:01 PM
yaya's Avatar
Default Re: quick Q about raising your redline (cancan)
cliff's notes:
what determine's the drop off of tourque? fuel map?
Old Jan 28, 2003 | 05:04 PM
tominos's Avatar
you could retard your timing so that you make some power at the top end. the point of raising the rev limit is so that you can take full advantage of the new cams you get. stock cams don't make much power after redline.
Old Jan 28, 2003 | 05:35 PM
TEG98's Avatar
Default Re: quick Q about raising your redline (tominos)
b18b redlines before 7000
are u talking about a b18c
Old Jan 28, 2003 | 06:55 PM
martini's Avatar
cams are what "determines" it for the most part.
[Modified by martini, 7:56 PM 1/28/2003]
B_Swapped93
17
Apr 4, 2013 12:51 PM
toolbox21
Oct 7, 2009 05:38 PM
theg35show
Mar 11, 2009 11:45 AM
steveteggy92
Mar 7, 2008 04:04 AM
integraracing91
May 9, 2003 06:16 PM
