QUICK ECU QUESTION!!!!?!?!?
Old Jul 22, 2005 | 05:45 PM
1sckcvc's Avatar
Default QUICK ECU QUESTION!!!!?!?!?
im running a b16a sir2 in an eg...want to use a gsr ecu to lower vtec engagement. is it plug and play or will it throw a cel? What would be the best ecu to get. Im clueless..any help appreciated.
Old Jul 22, 2005 | 05:51 PM
EHondaD6's Avatar
Default Re: QUICK ECU QUESTION!!!!?!?!? (1sckcvc)
<FONT SIZE="3">it will throw a cel</FONT>..it wouldnt hurt for you to try on your own though
Old Jul 22, 2005 | 05:58 PM
1sckcvc's Avatar
Old Jul 22, 2005 | 06:06 PM
EHondaD6's Avatar
Default Re: (1sckcvc)
theres no reason for you to lower the engagment point anyways..
Old Jul 22, 2005 | 06:14 PM
onepoint6i's Avatar
Default Re: (SE_DA)
Agreed..if you have cams or even stock cams it'll be better to raise engagment a bit...its always best to tune your engine though ... for sure.
Old Jul 22, 2005 | 09:32 PM
1sckcvc's Avatar
ok whats the best stock or chipped ecu to run with a b16a sir2??? i need like the code or whatever like p28 etc. etc.
Old Jul 22, 2005 | 10:43 PM
mtber's Avatar
Look into a chipped ecu.
If you need a chipped ecu or have any questions check out http://phearable.net
Modified by mtber at 8:41 PM 7/24/2005
Old Jul 23, 2005 | 04:46 AM
kenji's Avatar
Default Re: (mtber)
A chipped P28, P06, P05, etc. with the right map will run your setup very well.
If you have any questions check out my site http://www.kenji211.com
Or email me if you have any questions kenji211@tampabay.rr.com
-kenji
lilrobie69
Jan 13, 2013 09:36 AM
hondamoney
Jun 27, 2009 02:55 PM
kp
Engine Management and Tuning
16
Feb 13, 2009 09:51 AM
jimmy o.
Aug 27, 2008 09:44 PM
GsR92HaTcH
Apr 17, 2006 11:43 PM
