quick b17 rebuild tips?
Old Nov 11, 2001 | 08:59 PM
wignersfriend's Avatar
New User
Default quick b17 rebuild tips?
I'm going to do a basic rebuild (rings, rod bearings) in my apartment parking lot. My questions are basic, and I do have a Helms. Is there any time saving advice you guys have, so I can get this done in a weekend? In my mind it seems pretty cut and dry. Remove downpipe, head, oilpan, rod caps. Push piston/rod assy out the top, replace rings and bearings, and reverse. And I need to replace the head bolts, rod bolts w/ new ones? I need have all his in advance:
-rod bearings (will a certain color work regardless, w/o using plastigage and then ordering bearings?)
-headgasket
-head bolts
-rod end bolts
-rings
-assembly lube?
anything else? thanks...
Old Nov 11, 2001 | 10:29 PM
vhd's Avatar
vhd
Default Re: quick b17 rebuild tips? (wignersfriend)
i would personally not do a quick overhaul like that. the new piston rings will not seat correctly if you don't get the cylinders deglazed. if your getting the honda bearings i would suggest getting them by the certain color it needs because they are selectively fit. check the bolts to see if they have been streched or damege if they're not, then there is no need to replace. don't use a assembly lube that is moly-based, the lithium grease should work(white), make sure you use the rubber booties that goes over the rod bolts so it doesn't knick the crankpin
Old Nov 12, 2001 | 03:01 AM
rainforest's Avatar
rod bolts and head studs go for arp your motor will be able to handle a beating. Also i would get new oil seals.
johnjohn316
Mar 26, 2014 12:02 PM
4g hatch
Jul 7, 2010 08:08 AM
MeathooK
Jun 19, 2008 12:35 AM
GSR_hatch936
13
Jun 1, 2008 08:03 PM
GarageAlchemist
Jul 16, 2006 10:54 AM
