Questions about swap. With Coolant lines
Can yall check my coolant lines. The red X is onver the throttle body which I'm not going send coolant into. I dont know where the coolant line goes from iac and I'm not sure how it gets there. I am using two different colors to show where I think they go. Please tell me if I'm correct. Here is the image
http://www.latech.edu/~tlp006/car/swap/
Nick
Nick
The IACV returns to the coolant pipe on the block. Run the line from where you've got the gree questio mark. That should be the same even if your going to bypass the TB and FITV.
JDM00SI
Jan 8, 2007 09:06 AM
