question for the ones that know
Old Jan 8, 2003 | 06:43 AM
dip-set's Avatar
Default question for the ones that know
what components should be replaced to to assure maximum output on a stock engine , meaning with out getting into tearing the engines internals apart to do so.
example: plugs wires cap rotor fuel and air filter have been done...
my next thing will be timing belt water pump drive belts valve adjustment mtf will be drained and changed power steering fluid will be flushed and changed...after taking these steps in bringing the maintenence up to par... what steps should i take next to complete a full maintence tune up/service....thankz in advance for your time....
Old Jan 8, 2003 | 06:57 AM
Desslok's Avatar
Default Re: question for the ones that know (teg-your-it)
Coolant flush, replace T-stat, Brake fluid flush. Adjust timing, and get your injectors cleaned professionally, if you can be without the car, send them in to RC engeineering. Clean out throttle body.
Old Jan 8, 2003 | 07:04 AM
dip-set's Avatar
Default Re: question for the ones that know (sp)
ok coolant flush and brake fluid flush will do along with t-stat..as fas as being able to send out the throttle body i doubt it cause this is my daily driver so i need things done in a day or so...thankz for the advice though..
Old Jan 8, 2003 | 07:09 AM
Desslok's Avatar
No, you can clean the TB yourself. Just take off the intake and with a can of spray TB cleaner spray the heck out of it, clean off all the deposits off of it and the plate. The injectors I would have pressure cleaned by a service center, where they disonnect your fuel and run the car off of pressurized cleaner. The ones you buy at Pep Boys don't work as well.
Old Jan 8, 2003 | 07:15 AM
dip-set's Avatar
sounds easy enough to do but with my luck and my past luck with cars and trying to do things myself i"ll run into other probs. get aggrevated and *** things up more..besides the nagging wife"all u wanna do is mess with that car" doesnt see eye to eye with me on these things...but all in all thanks again...
Chris404
Mar 13, 2013 11:40 AM
tacchan
Mar 7, 2010 02:21 PM
RNPoo7
Aug 21, 2005 02:05 PM
Ms.JDMdb8
Jul 9, 2005 06:34 AM
who00knows
Jul 31, 2003 05:39 AM
