Question Concerning Master Cylinder for ITR/CTR 5 lug.
Old Nov 9, 2003 | 07:16 PM
mtber's Avatar
Default Question Concerning Master Cylinder for ITR/CTR 5 lug.
Hello,
I have a 95 Integra RS NON ABS with a 40/40 valve & factory brake cylinder & booster.
I had s2000 5 lug installed (dont ask how etc)
My brakes felt like **** with it. I bled & bled & bled.
I wanted to know if I will have this issue with ITR or CTR brakes ?
Should I upgrade my M/C & used my booster ?
If so what should I upgrade to ?
Remember, I have non abs hence I do not think the type-r M/C will work.
Thanks,
John
Old Nov 9, 2003 | 08:57 PM
BluLude's Avatar
Default Re: Question Concerning Master Cylinder for ITR/CTR 5 lug. (mtber)
what do you mean when you say it feels like ****, no pedal? or spongy or it has a normal pedal but you just dont stop?
Old Nov 9, 2003 | 09:16 PM
mtber's Avatar
with the car off 1st push was 1/2 of the pedal until i felt pressure then on the
2nd & 4rd push it got firmer.
once the car was on the pedal dropped to the ground minus a few inches when i pushed in the pedal
now i reinstalled my 4 lug & the pedal is about 80% better.
Old Nov 12, 2003 | 04:00 PM
BluLude's Avatar
Default Re: (mtber)
did you use the same master cylinder btw, like the same stock one in your car or did you use the s2000 one?
Old Nov 12, 2003 | 04:52 PM
mtber's Avatar
I used the 15/16's integra RS w/ the 40/40 prop valve
I dont think I can use anything else since I dont have abs.
rjp4419
Suspension & Brakes
15
Oct 28, 2010 06:46 AM
red96civicex
Suspension & Brakes
11
Feb 11, 2009 02:13 PM
LoNgHoRn
Mar 11, 2007 11:07 AM
jdmB18CT-R
10
Aug 14, 2006 11:42 AM
SPOONfdEK
Oct 29, 2003 08:21 AM
