question for cali peeps!!
Old Jul 2, 2002 | 11:05 PM
speshuled619's Avatar
Default question for cali peeps!!
how hard is it to pass a motor swap at a cali ref station? what would i need to make i have done before going in?
Old Jul 3, 2002 | 12:19 AM
kinesistech's Avatar
Default Re: question for cali peeps!! (speshuled619)
make sure you put your stock motor back in before you go to the ref.
Old Jul 3, 2002 | 09:26 AM
Default Re: question for cali peeps!! (kinesistech)
but i wanna try to pass with a swap. i heard of people passing with swap at the ref but im not sure what a motor needs to pass the ref inspection.
Old Jul 3, 2002 | 09:44 AM
Spade's Avatar
Motor must be same year or newer.
Must have no codes.
Must have good idle.
Must have documentation stating that the ECU you are using is for that motor.
If JDM, must have all smog equipment of USDM equivalent.
Old Jul 3, 2002 | 12:16 PM
erniecars's Avatar
Default Re: question for cali peeps!! (Spade)
check out this thread i posted a while back. its all the info the ref will give you on engine change overs. https://honda-tech.com/zerothread?id=208921
Old Jul 4, 2002 | 10:05 PM
thanks a lot for everyones help
kDA
Aug 9, 2006 10:16 AM
ironchef25
Nov 5, 2003 02:58 PM
EclipticX
Sep 29, 2003 05:35 AM
Dc5-Power
Jul 8, 2002 03:12 AM
