question about ls/vtec build..................
Old Jul 8, 2004 | 06:37 PM
bracket 4 life's Avatar
Default question about ls/vtec build..................
I am putting ctr pistons in my ls block and was wondering what will be the best as far as oem rods I have ls but will buy what will work best with the rods and I heard compression will be around 12-8-1 I was wondering if it would be streatable with ctr cams and rocket valvtrain if I retarded the timing also thanks for the help and what kinda of power should I expect with those mods
Old Jul 8, 2004 | 08:12 PM
mmuller's Avatar
Mad Scientist
Default Re: question about ls/vtec build.................. (infamousCW-hatch)
stock ls rods will be fine, you'll need lots of tunning though
Old Jul 11, 2004 | 12:12 AM
Default Re: question about ls/vtec build.................. (mmuller)
cool thanks man
Old Jul 11, 2004 | 12:40 AM
Grubb's Avatar
If you plan on taking the engine into the rev ranges of a factory vtec engine, it would be a wise choice to invest in some ARP rod bolts though. While the ls rods will be okay, those rod bolts weren't exactly engineered with 8000+ rpm revs in mind.
Old Jul 11, 2004 | 01:14 AM
Default Re: (Grubb)
thanks again
Old Jul 11, 2004 | 05:50 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (infamousCW-hatch)
ARP rod studs, Balance / micropolish the crank too.
Old Jul 11, 2004 | 01:17 PM
Default Re: (LSVTEC 91 Civic)
what kind of power numbers you think I might have like high 170's is what I was hoping for
Old Jul 12, 2004 | 10:34 AM
Spoolin84Gsl-se's Avatar
I am also in the process of doing an LS vtec swap. I have most of the parts ready. My question is, is it worth keeping my LS pistons, or is an upgrade a must? any help is apreciated.
Thank you!
Old Jul 12, 2004 | 11:33 AM
gsrmike's Avatar
Default Re: (Spoolin84Gsl-se)
Id say its a must because the LS pistons dont have deep enough valve reliefs for the VTEC head
Old Jul 12, 2004 | 12:30 PM
Combustion Contraption's Avatar
Plus your compression will be super low. HP wise youd be right around a b16.
Old Jul 12, 2004 | 12:58 PM
I3ackfire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolin84Gsl-se &raquo;</TD></TR><TR><TD CLASS="quote">I am also in the process of doing an LS vtec swap. I have most of the parts ready. My question is, is it worth keeping my LS pistons, or is an upgrade a must? any help is apreciated.
Thank you!</TD></TR></TABLE>
Look into JDM P73 pistons. CTR pistons usually yield to high of a compression ratio to run pump gas if you want to keep it streetable.
Old Jul 14, 2004 | 09:59 PM
Default Re: (I3ackfire)
bump
Old Jul 14, 2004 | 10:10 PM
mmuller's Avatar
Mad Scientist
pr3's or p30's are a nice street setup, the will put your compression around 11.5 using a pr3 head and p30's.
And are a lot lighter than pct's.
And not the headaches of high 12's compression tuning..
Old Jul 17, 2004 | 02:52 PM
bump
Old Jul 19, 2004 | 06:35 PM
bump
Old Jul 20, 2004 | 08:42 PM
bump
Old Jul 21, 2004 | 04:55 AM
Sliced Beard's Avatar
go to this link and mess with variables and see what you need to do......pct's (CTR pistons) will not give you 12.8:1 on a LS....it will be more like 12.2:1 unless you mill the crap outa the head
compression calculator
Old Jul 21, 2004 | 07:27 AM
mmuller's Avatar
Mad Scientist
Default Re: question about ls/vtec build.................. (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">go to this link and mess with variables and see what you need to do......pct's (CTR pistons) will not give you 12.8:1 on a LS....it will be more like 12.2:1 unless you mill the crap outa the head
Actually learn your facts buddy...compression of pct's on ls block is around 12.8 since compression height on pct's is different than other pistons; wich will yield 00 compression height..
Dont give wrong info if you dont know what your talking about...
Old Jul 21, 2004 | 07:57 AM
you are correct ......they run -o.010" on a b16/17 block, forgot about that
g0tgot
Aug 30, 2008 10:59 AM
sanegb16
Apr 24, 2008 06:22 AM
imskatencrzy
Sep 30, 2006 07:12 PM
imskatencrzy
Sep 30, 2006 02:56 PM
killerpenguin21
Jul 5, 2006 09:09 PM
