put b16a2 in 96 gsr
Old Feb 10, 2002 | 07:40 AM
b18c-93's Avatar
New User
Default put b16a2 in 96 gsr
a friend of mine blew his gsr engine for now till be builds his motor we out a b16a the b16a has no crank sensor next too the pully as the gsr and the ecu is reading that sensor so what can i do too fix that ot bypass that can somebody please help,
Old Feb 10, 2002 | 08:46 AM
HXMan's Avatar
Default Re: put b16a2 in 96 gsr (93gsb16a)
You will need to get an OBD1 conversion harness, and run an OBD1 ECU. That is the only way.
Oh, try using some punctuation!
Old Feb 10, 2002 | 08:48 AM
FSTASNTZ's Avatar
I beleive if you change to the GS-R oil pump (96 and up) that you can mount that crank sensor and run just fine. Other than that, you would have to get an ECU that eliminates that feature (OBD1)...
Jason
Old Feb 10, 2002 | 11:38 AM
b18c-93's Avatar
New User
Default Re: put b16a2 in 96 gsr (FSTASNTZ)
thanks guys for your help
Old Feb 10, 2002 | 01:06 PM
HXMan's Avatar
Jason
Cool!
pinoyboy204
Nov 9, 2007 05:21 PM
stealth_EK4
May 6, 2005 11:40 AM
CRX T-Si
Jan 8, 2004 05:03 AM
gotjesus
Nov 7, 2003 09:03 PM
