Pulling out H22A
Old Jan 1, 2003 | 06:34 PM
93H22ACX's Avatar
Default Pulling out H22A
Quick question.....when pulling out the H22A1 motor, does it matter if the car is in neutral or not? Because I believe mine was in 1st gear......
Thanks in advance
Old Jan 1, 2003 | 06:42 PM
HybriDNA's Avatar
Default Re: Pulling out H22A (95PRELUDEVTEC206)
Doesn't matter what gear its in when you pull it out. You can manually change gears with your hands when the motor is out anywayz. Just remember to pull the E-brake
Old Jan 1, 2003 | 11:39 PM
93H22ACX's Avatar
Default Re: Pulling out H22A (10psi)
do you know what usually causes the gears to be off set? about 2 years ago, my friend had a 1996 Prelude vtec and he changed his clutch. This caused 1st to be where 3rd is and 4th to be where 5th is....any clues? Thanks!
Old Jan 2, 2003 | 12:08 AM
Kamin's Avatar
um
maybe because he cant reinstall a transmission?
doing a clutch has nothing to do with the inside of the transmission, and NOTHING should change, he reinstalled the linkages incorrectly.
Old Jan 2, 2003 | 11:21 AM
93H22ACX's Avatar
Default Re: Pulling out H22A (Kamin)
[QUOTE]um
maybe because he cant reinstall a transmission?QUOTE]
hahahahaha i think so too.....
SoFresh1189
Dec 16, 2013 05:37 AM
flatline911
May 15, 2007 04:36 PM
korndog
Jun 11, 2005 03:14 PM
RebelleadeR
Jun 28, 2002 07:59 AM
