Prothane or Energy suspension?
Old Nov 10, 2002 | 08:57 PM
-Racer X-
Guest
Posts: n/a
Default Prothane or Energy suspension?
im thinking of getting a full bushing kit for my car (including motor mounts), which would you guys reccomend for best preformance and long lasting?
Old Nov 11, 2002 | 04:10 AM
Ricky Rojales's Avatar
Default Re: Prothane or Energy suspension? (-Racer X-)
Either will work... just use lots of graphite/moly grease.
Long lasting OEM
[Modified by P, 8:11 AM 11/11/2002]
Old Nov 11, 2002 | 02:11 PM
90TegRex's Avatar
I can't say much as I haven't gotten the master kit from either, but I have gotten a few things from Energy suspension (I.E. rear control arm kit). I had to contact them about some advirtising issues with their product, and they were really good to work with. I do know that the prothane were cheaper last I looked, but I was pretty happy with the way the people at ES dealt with me.
Old Nov 11, 2002 | 02:25 PM
-Racer X-
Guest
Posts: n/a
anyone else?
Old Nov 11, 2002 | 02:54 PM
smokin rubber's Avatar
I like my prothane bushings.
Old Nov 11, 2002 | 02:55 PM
Prod's Avatar
I had ES motor mounts on my previous Civic and I was happy with them, definitely helped with wheel hop
[Modified by Prod, 11:56 PM 11/11/2002]
Old Nov 11, 2002 | 03:27 PM
Turbo Powa's Avatar
Default Re: Prothane or Energy suspension? (Prod)
I like my Energy suspension bushings!
Old Nov 11, 2002 | 05:43 PM
Kataku2K3's Avatar
Default Re: Prothane or Energy suspension? (Panda EK)
For motor mount bushings i prefer Prothanes.... They both will work but Prothane is a bit stiffer.. If you are really trying to stop wheel hop i would just go with a traction bar then you really don't even need inserts... The Energy's work i just don't like them as much because they aren't quite as stiff.. The Prothanes do vibrate the car more (especially the rear), but if it's gonna vibrate then why not just go with the stiffer ones.
Old Nov 11, 2002 | 08:48 PM
-Racer X-
Guest
Posts: n/a
Default Re: Prothane or Energy suspension? (JDMspecEG6)
ya, thats the answer i was lookin for, i want stiffer bushings.
Old Nov 11, 2002 | 11:27 PM
-Racer X-
Guest
Posts: n/a
up top
Old Nov 12, 2002 | 02:00 AM
civic23g's Avatar
I have only the energy engine mount bushings in my car and plan to get the rest of the energy suspension kit but i hear that the prothane bushings are a bit stiffer,i believe the prothane kit is a bit more expensive though.
Old Nov 12, 2002 | 02:43 AM
kinesistech's Avatar
Default Re: Prothane or Energy suspension? (civic23g)
I have no experience with Prothane but I installed a full kit when I used to have a crx. I was impressed and immediately noticed the difference. I really dont think that the difference in stiffness will be noticable or benefitial between the ES and Prothane, I would just choose the cheaper of the two.
Old Nov 12, 2002 | 04:22 AM
Lord Quaalard's Avatar
Default Re: Prothane or Energy suspension? (kinesistech)
I have Energy Suspension on every bushing on my car. I have nothing bad to say about them. Only be prepared for a sharp decrease in ride quality. Also if you use the motor mounts and have a new cam. Be prepared for the increased vibration. Before my cam clears out my steering wheel vibrates badly. And as P said use lots of graphite, or it will squeak like Farris Bueler on the clarinet.
Old Nov 12, 2002 | 08:49 AM
Kataku2K3's Avatar
Default Re: Prothane or Energy suspension? (MrDyrten)
Really there isn't that much a difference in price....... I can't really find Prothanes anymore from anywhere besides JC Whitney... The shop that I go through lost the part number for them so they can't get them anymore... For an EK off JCW they run like $35 + shipping, and the DC/EG kit is like $55 plus shipping.. Energy's are about that same range but the kit is different... Prothanes come with the driverside and tranny side upper mounts along with the rear.. Energy's come a little different with the rear and the two lowers.. Why they do this i do not know.. Prothane for me tho.....
[Modified by JDMspecEG6, 9:50 AM 11/12/2002]
Old Nov 12, 2002 | 06:05 PM
-Racer X-
Guest
Posts: n/a
ya, i think ima go with the stiffer, cheaper ones (prothane)
Old Nov 12, 2002 | 06:50 PM
sauceman's Avatar
Yeah, I got the prothane on my Accord, and they are quite stiff, and give a way better road feel, though not too many bad vibrations, I expected more vibrations, but pleased by the compromise. I don't know about the availability issue in the US, but I had a hell of a hard time getting them up here in Mtl
Old Nov 14, 2002 | 05:16 AM
4bidden's Avatar
Default Re: Prothane or Energy suspension? (sauceman77)
do you need to use any graphite grease when installing just the motor mount inserts?
Old Nov 14, 2002 | 05:28 AM
Default Re: Prothane or Energy suspension? (4bidden)
The grease is there to minimize squeeeking.
Old Nov 14, 2002 | 08:39 AM
sauceman's Avatar
Default Re: Prothane or Energy suspension? (P)
And make sure you're very generous with the grease, because they do squeak like hell!!!
Old Nov 14, 2002 | 08:45 AM
94CivicSi's Avatar
do you need to use any graphite grease when installing just the motor mount inserts?.
I did not and they do not squeek. In fact, the instructions with the motor mount inserts tells you to make sure the surface of the existing mount is clean and free of dirt and grease. Unlike the rest of the bushings, they're Poly on rubber, not Poly on metal, so there is nothing to go "squeek".
Old Nov 14, 2002 | 09:36 AM
-Racer X-
Guest
Posts: n/a
Default Re: Prothane or Energy suspension? (94CivicSi)
good lookin out player.
blink_977
Dec 8, 2008 11:36 AM
madracer
Suspension & Brakes
10
Oct 25, 2008 02:29 PM
maynards_ek
Oct 31, 2007 09:17 AM
zither
Nov 5, 2004 01:13 PM
ragejed
Nov 21, 2003 11:54 AM
