proiblems after timing belt change
Old Apr 10, 2006 | 04:07 PM
Mentat Ghola's Avatar
Default proiblems after timing belt change
i changed the timing belt on my sisters CRV, since then theres been problems. First she said it owuldnt start right away, now it tends to stall when its cold. The best thing i could think of is the crank position sensro. I did mess with it, removed it and reinstalled it, and i disconected hte plug and reconected it. Would this cause the stalling? Does the ECU look at thecrank sensro after sarting? I thought this sensor was only for initial startup and then the dizzy takes over, i oculd be wrong. Does this sound reasonable? Any other sugestions? Would a leaking water puimp cause this? Water acumulating on the botom of the cover while the car sits at night? please help meout, im gonna tear it down again tomorow.
Old Apr 10, 2006 | 04:27 PM
rainforest's Avatar
Default Re: proiblems after timing belt change (Mentat Ghola)
unless its covered is some kinda spray like silicone or the sensor was on its way out and now its intermittenly having issues or its not bolted in corectlly its most likly not your fault the crv's are know for ignition switches going. there is a open recall on the ignition switch i would bring it to honda and let them know. also the ckf sensor would throw a code or just never start.
Old Apr 10, 2006 | 04:37 PM
Default Re: proiblems after timing belt change (rainforest)
so the crank sensro would throw a code eh, what year is the recall on?
does the recal mean that the dealer will fix it?
Old Apr 10, 2006 | 04:38 PM
she also said thta it runs rough until it warms up. I dont know how much i trust that, she might not know whta shes tlaking about.
Old Apr 10, 2006 | 04:42 PM
another idea, could an overtight belt cause this
Old Apr 10, 2006 | 04:43 PM
rainforest's Avatar
yes its free. no the ignition switch would not cause the car to run rough.
Old Apr 12, 2006 | 07:53 AM
HOsNiDA's Avatar
TRY CHECKING THE TIMING AND MAKE SURE YOU PUT IN TIME. WHEN CHANGING TIMING BELTS PARTS WILL MOVE.
Gunnar72
Jul 5, 2014 06:32 PM
patm95
Honda Civic (2001 - 2005)
Oct 4, 2013 06:29 AM
sickofitall1113
Nov 23, 2006 09:39 PM
Mentat Ghola
Apr 14, 2006 07:44 AM
aaaabbbb
Oct 5, 2004 03:02 PM
