problem with my tach
Old Oct 9, 2003 | 10:14 PM
showty's Avatar
Default problem with my tach
the tachometer of my 2000 si stops working when i floor it and vtec starts, it freezes around 5 or 6 thousand rpm, but the engine works properly, after a while the tach starts to work right, sometimes it takes like one or two days to return to normal, anyone knows why
Old Oct 10, 2003 | 02:28 AM
jde_07's Avatar
Default Re: problem with my tach (showty)
it sounds like your tach is going out on you if it was jumping around I would say it is altenater. It also could be a bad ground or loose conection somewhere. I would check all your connections first.
lexusgui
Jul 27, 2008 07:54 PM
AMChev
Nov 1, 2005 05:49 AM
CimorelliCRX
14
Jul 2, 2005 02:25 PM
loopie2128
Jan 28, 2005 05:04 PM
