problem...help!
Old Aug 12, 2003 | 03:38 PM
bOOsTiNSoHcVtEc's Avatar
Default problem...help!
today my friend wanted to ride in my car since he hasnt in awhile...so he was like gun it so i went from 1st and wheel hopped 2nd and missed 3rd and stopped. My battery light and abs light came on after that and wont go off. Now i cant figure out whats wrong and i hope its not draining my battery cause i need my car for work since i jus started working at the place. Anyone got a solution or know whats wrong...please help
Old Aug 12, 2003 | 04:12 PM
Chiovnidca's Avatar
Default Re: problem...help! (bOOsTiNSoHcVtEc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">Anyone got a solution or know whats wrong...please help</TD></TR></TABLE>
Check your fuses and charging system.
Old Aug 12, 2003 | 04:45 PM
Default Re: problem...help! (Chiovnidca)
i did...its a brand new alternator and brand new battery cause i went through this b4 and found out it was a short from my wiring harness to the underhood fuse box...replaced the wiring harness and everything was fine. The battery is at full power but when i turn on my car and check the voltage it doesnt go up it stays the same. I dont have a fuse map but the 7.5 fuse doesnt light up when the car is on when i take a test light to it. Im assuming this is the alternator fuse but i took out the fuse and it looks fine. I dont understand how gunning my car can do this?
Old Aug 12, 2003 | 04:48 PM
PHiZ's Avatar
Well, you wheel hopped, and then the ABS light came? maybe you messed up an ABS sensor...
-PHiZ
Old Aug 12, 2003 | 05:13 PM
Default Re: problem...help! (PHiZ)
how come the battery light is on though? and if it is how would i go about fixing this abs sensor and where is it?
91grape
11
Dec 16, 2012 12:25 PM
akinas-crx
Oct 21, 2010 09:44 PM
rewerbcrx
14
Aug 16, 2007 11:42 PM
JasonST
Jul 10, 2006 12:30 PM
streetsweaper
Dec 7, 2005 05:12 AM
