Problem with the electricity..
Old Apr 28, 2011 | 06:15 PM
ALLDAY-24's Avatar
Default Problem with the electricity..
when i start my car it runs, but then it dies when i take off the negative from the battery, so i bought a new alternator and then i did it again and it still died when i took off the negative from the battery... so i changed the fuse box and it is still doing the same thing.. what is wrong with my car? it is a honda civic sir motor.. I know that it is just running from the juice in my battery..
Old Apr 29, 2011 | 08:01 AM
slowcivic2k's Avatar
Default Re: Problem with the electricity..
Check the pinout on the alternator, odds are the field control circuit is not working. make sure the alternator is hooked up and turning... should be a no brainer.
NEVER remove the negative battery terminal with the car running, you will overheat the diodes in the alternator and ruin it.
Old May 1, 2011 | 10:00 AM
ALLDAY-24's Avatar
yea, car still is not running...
Old May 2, 2011 | 08:37 AM
NVturbo's Avatar
O.G. triple O.G.
Like slowcivic2k said...don't remove the negative terminal with the engine on. Check the voltage of the battery with a multimeter.
1. With engine OFF, it should read about 11.5V DC. If not...bad battery.
2. With engine ON, it should read about 14.3V DC. If battery checks OK, you have a bad alternator.
Annihilator
Oct 14, 2009 04:55 PM
Choy
20
Jul 20, 2009 07:11 AM
aSDthing
Audio / Security / Video
Feb 9, 2008 04:00 PM
EG6R
May 10, 2007 01:57 PM
ID_ten_T
Nov 2, 2004 11:24 PM
