pressed ARP rod bolts?
Old Jul 2, 2003 | 10:39 PM
untitled's Avatar
Default pressed ARP rod bolts?
a local shop told me that you have to press these to install them correctly. is anyone familiar with this. i need to before i put together my new ls/vtec.
Old Jul 2, 2003 | 10:57 PM
IN VTEC's Avatar
Default Re: pressed ARP rod bolts? (88crx91integra)
True. Then you need to check the out-of-roundness of the big end. Pressing new rod bolts in can have tendency to distort the roundness of the big end.
I'd say .0002" is the limit of out-of-roundness for the big end.
Old Jul 2, 2003 | 11:11 PM
untitled's Avatar
Default Re: pressed ARP rod bolts? (IN VTEC)
how do you press in bolts that thread in?
Old Jul 2, 2003 | 11:20 PM
IN VTEC's Avatar
The shank portion of the rod bolt isn't threaded at all. It has to be press fitted into the rod.
Practically thinking about it, it shouldn't even be called a rod bolt...it's more like a rod stud and nut.
But, I shouldn't discount that you might not be using OEM rods. Aftermarket rods that I'm familiar with have all used rod bolts (ie: Eagle, Crower).
Old Jul 2, 2003 | 11:25 PM
Ivan's Avatar
senior gold member
I have an extra set of arp bolts brand new. if your interested let me know. My dads buddy can have them pressed in and checked for roundness too.
EGRhatch
Feb 5, 2013 08:49 AM
TheCrimsonGhost666
Dec 24, 2009 02:24 PM
GSR615
Jan 23, 2009 11:13 AM
turbociv
Sep 8, 2003 05:41 AM
FastFoot
Sep 28, 2002 12:09 AM
