prelude injector sizes?
Old Oct 28, 2002 | 08:29 AM
EFing8's Avatar
Default prelude injector sizes?
what are the prelude injector sizes and for what years? and what years will work in my first gen b16. I have access to a blown h23 so i wanna know if those injectors will work. thank you.
Old Oct 28, 2002 | 09:27 AM
H22Si's Avatar
Default Re: prelude injector sizes? (CND_CRX)
OBD1 H22 injectors are rated by RC at 345cc. I had mine flowtested by them a few months ago. RC claims the OBD2 H22 injectors to flow 290cc.
I don't know for a fact, but I believe the H23 injectors are rated at 240cc like the B series. Give RC a call and ask a tech for accurate info.
[Modified by H22Si, 3:09 PM 10/28/2002]
Old Oct 28, 2002 | 11:08 AM
Austin's Avatar
Default Re: prelude injector sizes? (H22Si)
'97+ Prelude injectors are 290cc/min
copy and past for the full size image:
http://www.imagestation.com/picture/...f.jpg.orig.jpg
Old Oct 28, 2002 | 11:09 AM
H22Si's Avatar
Default Re: prelude injector sizes? (Austin)
...ya, OBD2
Old Oct 28, 2002 | 12:06 PM
EFing8's Avatar
and what would i have to do to use the obd1 injectors or even the obd2 injectors on an obd0 car?
Old Oct 28, 2002 | 12:26 PM
satan_srv's Avatar
Let's get something straight, they aren't OBDI and OBDII injectors, they go by engine design
H22A1 injectors, which includes 93-95 OBDI and 96 OBDII ar the 310-330 (RC says 345?) Peak and Hold Type INjectors, they require an external resistor box. They are high impendance injectors.
H22A4 injectors, which is 97-01 OBDII engines, are the 290cc Saturated type injectors. I have not seen them myself, but the resistor is 'on' the injector. they are low impedance.
Unfortunately I know nothing about OBDO....but OBDI and OBDII ecus send the same injector signal, it's just a matter of using the right resistor/injector combo to make it work.
[Modified by satan_srv, 5:02 PM 10/28/2002]
Old Oct 28, 2002 | 12:57 PM
EFing8's Avatar
Default Re: prelude injector sizes? (satan_srv)
thank you, that answers my question. 92-95 SR-V injectors it is then.
Old Oct 28, 2002 | 01:02 PM
satan_srv's Avatar
no that's actually 93-96 SR-V injectors. No SR-Vs in 92 and the 96 has the same ones
Old Oct 28, 2002 | 01:16 PM
Austin's Avatar
What the majority of people are talking about when they are saying OBDI and OBDII injectors is speaking about the injector plugs...the OBDI and OBDII injector plugs are different, and would require you to change out the plugs to get an injector from an OBDI car to work in an OBDII car...hence the reason of using the '97+ Prelude injectors, allowing you to use the injectors as a simple drop-in modification, not wiring changes needed.
Austin
Old Oct 29, 2002 | 09:11 AM
H22Si's Avatar
ya 345cc, i have the flowsheet in front of me
Old Oct 29, 2002 | 03:02 PM
pinota's Avatar
I´m using 97+ prelude injectors on my ITR and i believe they´re high impedance, saturated.
Old Oct 29, 2002 | 05:58 PM
tinkerbell's Avatar
lets get something MORE straight, and less WRONG...
Peak and Hold are LOW impedance ie 2-4ohms
Saturated are HIGH impedance ie 10-14 ohms.
OK?
t..
rmiller
Feb 2, 2008 09:58 AM
wpgcivic
Jul 18, 2005 11:27 PM
The DX Rex
Feb 12, 2005 01:05 PM
DCFIVER
Sep 12, 2004 07:55 PM
egizzle8
Mar 18, 2004 09:52 AM
