prelude bogging...need help
Old Aug 14, 2002 | 06:32 PM
jarel's Avatar
Default prelude bogging...need help
my brothers prelude sh has intake/headers/exhaust/cam gears. it was all dyno'd and tuned over at atomic/import builders about 5 or 6 months ago.
he said that whenever he punches it from 1st gear, the throttle response is slot and doesn't pick up till around 4kish.
i drove his car and i noticed that it does have a lag when you punch it off of 1st.
does anyone know what could be the problem? is that how the prelude sh's are?
Old Aug 14, 2002 | 06:42 PM
aklucsarits's Avatar
New User
Default Re: prelude bogging...need help (chyknees)
Defining "slow throttle response" is difficult. Was it sluggish even on the dyno? If that's the case, the dyno plot would be helpful to help diagnose the issue.
Just based on your vague description, a slipped adjustable cam gear seems like it could be a likely culprit if the symptoms just appeared recently...
Andrew
Old Aug 14, 2002 | 06:46 PM
jarel's Avatar
Default Re: prelude bogging...need help (aklucsarits)
sorry...should've been a bit clearer. when you put it in 1st gear and put the pedal down...it acts laggy/sluggish and slowly makes it way up and then around 4k or so it opens up like normal.
it might be the cam gear, because my brother said something about it looking off after getting it back from teh body shop.
could there be any other problems?
Old Aug 14, 2002 | 06:54 PM
New User
I have a Prelude with I/H/E. It's not too peppy until I hit 3300rpm or so... But if his is bogging to the point where pinging can be heard, I would guess the cam gears...
Andrew
alterdcreations
Jan 24, 2007 11:45 AM
92_civic
Sep 14, 2005 06:44 AM
xbn83
Dec 11, 2004 08:26 PM
