PR3 ecu
Old Sep 6, 2005 | 09:04 PM
proracer718's Avatar
Default PR3 ecu
Can a pr3 ecu be chipped like a p28??
Old Sep 6, 2005 | 09:09 PM
rev-speed's Avatar
yes
Old Sep 8, 2005 | 08:39 AM
b18_crx's Avatar
Default Re: (rev-speed)
what are the actual specs on pr3............like revlimit and are diffrent variants of pr3? sorry dint mean to threadjack!?!?!?
Old Sep 8, 2005 | 08:53 AM
drdisco69's Avatar
Default Re: PR3 ecu (proracer718)
It's not chipped just like a P28, since it's OBD0 (mostly) you just replace the rom with a socket, no parts to add.
The PR3 has an 8000rpm rev limiter and 6565 vtec point. As far as I know, the JDM and EDM variants have the same specs. Anyone confirm?
Old Sep 8, 2005 | 09:24 AM
b18_crx's Avatar
Default Re: PR3 ecu (drdisco69)
8000k rpm? 6565 vtec engagement.........kinda high i thought it was maybe 45 or 4700
Old Sep 8, 2005 | 10:37 AM
drdisco69's Avatar
Default Re: PR3 ecu (b18_crx)
Well there's 2 equations to get the vtec point from the ecu code, and the one Crome uses yields 6565, while BRE says 4700ish. It's been so long since I've driven a stock PR3, I don't know what it is anymore...
Old Sep 8, 2005 | 10:44 AM
b18_crx's Avatar
does anyone know for shure?
Old Sep 8, 2005 | 12:26 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know for shure?</TD></TR></TABLE>
dude
u can chip it
well all u do is change the eprom
its not like a obd1 ecu that u have to add chips and mod it
anyhow
go to pgmfi.org
Old Sep 8, 2005 | 01:09 PM
kelchyn's Avatar
my JDM ODB0 PR3 vtec was at ~4700 stock.
Old Sep 8, 2005 | 01:25 PM
b18_crx's Avatar
Default Re: (b18_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">what are the actual specs on oem pr3............like revlimit and are diffrent variants of pr3? sorry dint mean to threadjack!?!?!?</TD></TR></TABLE>
i dont wanna chip it. just need specs
Old Sep 9, 2005 | 07:40 AM
b18_crx's Avatar
i dont wanna chip it. just need specs</TD></TR></TABLE>
ANYONE?
Old Sep 9, 2005 | 11:39 AM
hondaxsimike's Avatar
you can definitely chip it. for dirt cheap too. i have three different chips
for my pr3. all i do is take the ecu cover off pop one out and pop the new one in.
as for the stock vtec point i thought it was somewhere around 5200 or so.
if you chip it that might change though
Old Sep 9, 2005 | 03:59 PM
Mr Synister's Avatar
Default Re: PR3 ecu (kelchyn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelchyn &raquo;</TD></TR><TR><TD CLASS="quote">my JDM ODB0 PR3 vtec was at ~4700 stock.</TD></TR></TABLE>
me too just that my vtec kicks in at 4600 unless my tach is off a lil. as for red line i hear its 8000 and others say its 8200 all i know is that i dont try to hit the 8000 i usually shift a little before
Old Sep 10, 2005 | 03:00 PM
Ben Ogle's Avatar
Default Re: PR3 ecu (Mr Synister)
Crome uses OBD1 formula for obd0 vtec. The clock speed in the obd0 vtec ecus is different and thus the formula is different also. BRE is correct.
Ben
Old Sep 10, 2005 | 03:22 PM
drdisco69's Avatar
Default Re: PR3 ecu (Ben Ogle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ben Ogle &raquo;</TD></TR><TR><TD CLASS="quote">Crome uses OBD1 formula for obd0 vtec. The clock speed in the obd0 vtec ecus is different and thus the formula is different also. BRE is correct.</TD></TR></TABLE>
This explains the discrepancy in VTEC points between BRE and Crome. I wondered which was correct, thanks.
Old Sep 16, 2005 | 09:09 PM
Does anyone know wat Software can be used to program the chip for a OBD0 PR3 ecu?
Old Sep 16, 2005 | 09:16 PM
We tried Bre and Turboedit and changed the settings but it was the same when we tested it out.
DRAG_WORKX
Jan 15, 2007 08:07 AM
the.hamburglar
Dec 27, 2005 07:24 PM
Ls4thGen
Apr 23, 2005 09:02 AM
miller
Dec 9, 2004 09:47 AM
