post compression #s
Old Aug 5, 2004 | 05:02 PM
KillaB-'s Avatar
Default post compression #s
yo im trying to compare my compression numbers with other engines to see if i might have a problem. i have a b16 CTR pistons and stock headgasket and milled head. my compression reads 220 210 210 220 i just want a few examples to see if mine is too low or too high. its supposedly milled alot so there might be a problem. thx
Old Aug 5, 2004 | 05:20 PM
PodRacerSi's Avatar
Default Re: post compression #s (KillaB-)
I'll post mine as soon as I get the engine back together. I am in the process of putting CTR's in mine right now.
Old Aug 5, 2004 | 09:18 PM
anothersickhatch's Avatar
Default Re: post compression #s (PodRacerSi)
those numbers dont look so good...i have the same set-up and i compression tested mine a couple days ago..
275 275 270 270
i thought mine was a little low too...how much is your head milled?
Old Aug 7, 2004 | 11:24 PM
KillaB-'s Avatar
Default Re: post compression #s (anothersickhatch)
mine is definaltely milled over .020mm, it might be mire, becasue if use anything but ITR spark plugs, the pitons hit the spark electrodes and bend the **** out of them. just lookin for some more numbers to compare. whats cuases your compression to be soo low with a build like mine.
Old Aug 7, 2004 | 11:35 PM
mmuller's Avatar
Mad Scientist
b16 and 245/250 compression here.
and your domes hit the spark plugs....ouch
your rings could be worn...
you NEED to do a leakdown test to pinpoint the problem
Old Aug 8, 2004 | 12:04 AM
KillaB-'s Avatar
Default Re: post compression #s (mmuller)
alrgiht ill check a leakdown but yeah my domes hit the spark plugs. hmmm
Old Aug 8, 2004 | 12:06 AM
KillaB-'s Avatar
leakdown ok ill try that, but yeah the dome hits the spark plug hmmm
oh and the rings are new, did a rebuild less than 7k miles ago
Old Aug 8, 2004 | 02:32 AM
my plugs never hit...i used ngk's. what kind of fuel management/ecu are you running??
Old Aug 8, 2004 | 05:42 AM
Runnerdown's Avatar
same setup, cold engine we got 250 psi give or take a few.
Old Aug 8, 2004 | 08:45 AM
KillaB-'s Avatar
Default Re: (Runnerdown)
im running NGk plugs, the grade used in a type r, the gap size is about 2.5 mm smaller than the ones that a 2000 Si calls for, my ecu is a ericks racing chip, its setup is for a engine that is spraying 100 shot of NOS, but my car is NA. so there might be a problem with that. it runs really rich because of that.
Old Aug 8, 2004 | 11:44 AM
Default Re: (KillaB-)
fuel management is important with a milled head and ctr pistons because of the high compression. you may be running lean, or rich, which would cause the rings to seat badly. thats what happened to me, i ran too lean and detonated two pistons. i learned my lesson and got hondata.
Old Aug 8, 2004 | 08:17 PM
KillaB-'s Avatar
Default Re: (anothersickhatch)
hmm i think ill get a good tune them, maybe a ericks racing chip and vafc
Old Aug 9, 2004 | 12:08 AM
to tell you the truth though, i think its too late for all that. your compression is pretty low. i would get new rings and **** and then get it tuned that way you are getting the most power out of your b16
Old Aug 9, 2004 | 03:11 PM
KillaB-'s Avatar
say my rings did seat badly , could i get new rings and rehone the cyclinders or have to bore bigger
Old Aug 9, 2004 | 03:36 PM
dynamicauto's Avatar
new rings and a hone would be sufficient. theres no need to overbore. that would mean new pistons anyway.
Old Aug 11, 2004 | 05:34 PM
KillaB-'s Avatar
Default Re: (dynamicauto)
now how about when i rehone and put in new rings should i rebuild the block with new washers and bearings etc. or can i keep my old ones. they are not that old, say 7k miles on it.
Old Aug 11, 2004 | 09:34 PM
all youll need to do is replace the rings..everything else should be okay to reuse
as soon as you get new rings though, make sure you get it tuned asap. if your pistons are hitting your spark plugs i wouldnt even run the same setup cuz its just asking for trouble
Old Aug 12, 2004 | 02:58 PM
KillaB-'s Avatar
wouldnt using a fat head gasket like a .8 or 1 mm from TODa help me with my problem of my domes hitting my spark plugs, and the pistons dont hit all plugs, the integra type R spec NGk's are just short enough to fit with out contact of the piston.
also with that fat headgasket i would lower my compression considerably,
is this a good substitute for replacing the material that was milled off the head?
Old Aug 13, 2004 | 01:14 AM
i would honestly recommend NOT using extra layers of a headgasket to make up for the milled head...nothing but leakage problems. just make sure the pistons arent tapped the head or spark plugs and you should be straight.
Old Sep 1, 2004 | 04:42 PM
KillaB-'s Avatar
at what compression number for example 220 240 or 280 should you use a higher octane gas, what im looking for is like
at 240 compression use 94 octane gas or 91 with a good octane booster thrown in
anyone know this kind of information??
im expecting to have 280-290 compression and dont know what gas octane to use
Old Sep 1, 2004 | 07:26 PM
megotvtec's Avatar
130-140-120-40
cracked piston last friday
Old Sep 1, 2004 | 09:11 PM
maxrpm's Avatar
Default Re: (megotvtec)
220 all four this is a ls block with stock ls pistons.
Old Oct 21, 2004 | 10:43 PM
KillaB-'s Avatar
Default Re: (maxrpm)
Behan
Jun 12, 2007 08:23 AM
T3T495GSR
Jul 18, 2005 11:04 AM
rudebwoy
May 24, 2005 01:30 PM
lsvtecivic
Jan 29, 2003 05:07 PM
