Positive Camber Help
Old Jan 3, 2004 | 09:41 PM
S-Type1's Avatar
Default Positive Camber Help
Hello everybody,
I've lowered my 92 civic SI with H&R stage II springs years ago. since then, i've been in an accident. To make a long story short, my front left camber is +0.5 while my right side is -0.7.
I'm new to the idea of adding camber plates - i know there are different types with different ranges of tuning and diffrerent prices. All i want to do is change my left side to -0.7.
Any suggestions on where to start?
Old Jan 3, 2004 | 10:16 PM
S-Type1's Avatar
Default Re: Positive Camber Help (S-Type1)
okay, one thing i forgot to ask. given the seemingly simply nature of a camber kit, would i regret getting a kit made by a manufacture such as.... OBX?
Old Jan 4, 2004 | 12:38 AM
iam7head's Avatar
where is the link to the thread of someone using cheap *** camber kit and get the whole steering knuckle fw-ked?
Um...i wouldn't trust obx tho', it's like apc in the world of wings and altezza
Old Jan 4, 2004 | 08:40 AM
Padawan's Avatar
Darth ModerVader
Before you invest in a kit, you might want to check if the whole sub-frame has shifted slightly.
Old Jan 4, 2004 | 11:30 AM
S-Type1's Avatar
Default Re: Positive Camber Help (Padawan)
what would a shifted sub frame ultimately equate to?
Old Jan 4, 2004 | 03:06 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S-Type1 &raquo;</TD></TR><TR><TD CLASS="quote">what would a shifted sub frame ultimately equate to?</TD></TR></TABLE>
In some cases, the very camber numbers you are describing.
Edit: Although after looking at the numbers again, you would probably be seeing more negative camber on the one side if this was indeed the problem. It still couldn't hurt to investigate though.
Modified by Padawan at 8:48 PM 1/4/2004
Old Jan 4, 2004 | 05:03 PM
Dtuned's Avatar
...you suspension is bent on the LF, seen it many times- replace the bent part and have it align..... HTP-hondatech
bmoua
Suspension & Brakes
Oct 19, 2007 04:00 AM
bryandamatrix
Jul 18, 2004 01:00 AM
SiRocket02
14
Jan 11, 2004 09:24 PM
DC4 teg
Dec 17, 2003 04:17 PM
