plugs on h22a throttle body
there are two identical sensors on my throttle body on my h22a i swapped into my cb7, the f22 throttle body only had one, the maf sensor i guess. is the one on top the maf sensor and the other a tps sensor?
TPS sensor is on the opposite side of throttle plate from the throttle cable. The TB-mounted MAP sensor will be on the top or bottom. The one sensor your previous TB had was the TPS sensor because some honda motors have the MAP sensor mounted on the firewall behind the TB. The two sensors on your new TB should not be identical.
