please someone help me :(
Old Sep 9, 2009 | 04:46 AM
jdmekfouR's Avatar
Default please someone help me :(
my car isnt dont have spark the spark plugs smeems to be fine check all the fuses dont know what to do
Old Sep 9, 2009 | 05:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: please someone help me :(
MM&Y of car would help. 94
Old Sep 9, 2009 | 09:14 AM
dognutz's Avatar
How do you know you have spark issues and not fuel problems?
First check and make sure you have battery power near 12 or 13 volts.
second (since fuses have been checked) pull a spark plug wire put a spark plug in the loose end have someone try to start the car and look for spark at the plug tip. If no spark that points to the distributor or a part inside (ignitor, rotor, ect..). This is pretty common. Did you also check the ignition fuse under the hood?
GL
Old Sep 9, 2009 | 01:32 PM
8zero8's Avatar
even a little info will help dude...
Old Sep 9, 2009 | 03:57 PM
srmofo's Avatar
tow it to the nearest shop
Crossbreeder
Aug 16, 2010 05:52 AM
DelSlowmo
61
Feb 12, 2009 07:50 PM
skata89
May 21, 2006 03:32 PM
keithv
10
Mar 6, 2003 06:28 PM
Trinity
13
Sep 4, 2002 06:01 PM
