Please, need part numbers
Old May 15, 2004 | 05:58 PM
Boostage's Avatar
Default Please, need part numbers
I am putting in a quaife in my 96 LS tranny and I need 10 of the ring gear bolts and two countershaft thrust washers. what are the part numbers?
Old May 15, 2004 | 07:51 PM
_BEN_'s Avatar
Default Re: Please, need part numbers (Boostage)
you can probably buy them from http://www.acuraautomotiveparts.net but they dont list the pn's
Old May 16, 2004 | 04:52 AM
Boostage's Avatar
I been there, I cant even find the differential on that site.
Old May 16, 2004 | 05:22 AM
Rod.'s Avatar
Default Re: (Boostage)
http://www.acuraautomotiveparts.org
Old May 16, 2004 | 02:16 PM
Boostage's Avatar
Default Re: (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">http://www.acuraautomotiveparts.org</TD></TR></TABLE>
I cant find them on that site
Old May 16, 2004 | 02:33 PM
IN VTEC's Avatar
90017-689-000 BOLT, SPECIAL (10MM) [$3.26 x 10]
There's only one shim washer on the countershaft, located underneath the 1st gear. 23921-PK5-900 WASHER A [$4.28 x 1]
If you're talking about the 80mm differential shim, then you need to measure the clearance first before you know what thickness to order. Part numbers are listed in the service manual under the B18B1 differential section.
Destructive-
Feb 26, 2008 02:57 PM
Joel_MN
Honda Motorcycles
20
Mar 26, 2006 02:14 PM
spazz0nater
Acura NSX
Mar 8, 2006 06:26 AM
XstouterX
Nov 17, 2005 03:26 PM
DOHCRX
Jan 31, 2003 07:48 PM
