please help
Old Sep 24, 2003 | 02:20 PM
mattyg1405's Avatar
Default please help
hi i am running a b16a sirII with an ex harness in a 95 CIVIC EX i have a chipped p28 , i have a problem my car is running very lean and slow and its not the computer b/c i used it in a friends car and it runs correctly please help with and comments on what to check .........the map ,tps,are good i even swapped the injectors still no luck! the no engine code either?????? i dont know what to do next i even tryed a p30 and a obd1 pr3 nuting works ,,,,,,, if the timming was off would it do this? would it still run if the timming was off please reply asap!
Old Sep 26, 2003 | 10:42 AM
mattyg1405's Avatar
Default Re: please help (mattyg1405)
anyone know?
i know its running lean the plugs are whiiiitttteee...my ait/fuel pinned on lean any one ever have this problem?
Old Sep 26, 2003 | 10:45 AM
mmuller's Avatar
Mad Scientist
what kind of fuel pump and regulator are you using?
Old Sep 26, 2003 | 12:54 PM
mattyg1405's Avatar
im using an b&m and a stock fuel pump but its not the pump or the regulator i used the same pump with a jrsc and no probs
Old Sep 26, 2003 | 09:23 PM
mattyg1405's Avatar
bump bump bump b/c nobody like me!
Import_2
Oct 23, 2008 08:35 PM
92vx6
Sep 14, 2005 06:41 PM
sleepyEK
May 20, 2004 06:00 PM
cock head
Jul 30, 2002 11:47 AM
