Please explain "valve float"
Old Sep 25, 2002 | 09:41 AM
YodaIsGod
Guest
Posts: n/a
Default Please explain "valve float"
like the topic says. thanks!
Old Sep 25, 2002 | 09:46 AM
Spade's Avatar
Default Re: Please explain "valve float" (YodaIsGod)
Springs aren't strong enough to pull valve closed in time.....piston smack bang, clank clank boing bong.....damn.
Old Sep 25, 2002 | 11:31 AM
canuck-mx6's Avatar
Default Re: Please explain "valve float" (Spade)
Hahaha, that is an excellent explanation. I can just hear the piston hitting the valves
Old Sep 25, 2002 | 11:47 AM
Niozoin's Avatar
Default Re: Please explain "valve float" (canuck-mx6)
A slightly better explanation.....
Pistons and Valves are always reciprocating in motion in an engine, meaning they move back and forth. At high RPMs they both have to keep reciprocating, moving at very high speeds. Pistons are connected solidly to the crank via connecting rods so hopefully they do not "float" out of sequence, the valves on the other hand, are held against the Cams with spring tension. At high RPMs if the springs don't have enough tension on the valve the valve will "float".....basicly the cam lobe falls away from the top of the valve stem and the spring has to play catch up to get contact back......the float causes the largest problems in "interference" engines (meaning that the piston and valves will contact if the piston is up and the valve is down at the same time) by haveing the valve floating and not retracting the piston can hit the valve and bend the stem, locking it into position, probably breaking, and screwing everything up.
Old Sep 25, 2002 | 12:56 PM
3rdGteg's Avatar
Default Re: Please explain "valve float" (Niozoin)
Well said.
Old Sep 25, 2002 | 01:11 PM
MisterHYBRID's Avatar
haha...thats great, reminds me of chitty-chitty bang bang
Old Sep 25, 2002 | 01:35 PM
WAFFLES's Avatar
Default Re: Please explain "valve float" (MisterHYBRID)
huh-huh you said bong.
Old Sep 25, 2002 | 01:37 PM
Spade's Avatar
Default Re: Please explain "valve float" (WAFFLES)
Yup.....lots of white smoke.......................and blue and possibly black too.
Old Sep 25, 2002 | 07:50 PM
HotWheelz's Avatar
Fixed a 2001 type-R TWICE.... bent all valves but engine was still in one peice.... not bad for somethign that went about 11,000rpms... redlined 3rd and droped in second.... (not mine)
amazingly the bottom end stayed in once peice... type=r = tough!!
Old Sep 26, 2002 | 05:29 AM
jweller's Avatar
Default Re: Please explain "valve float" (HotWheelz-turboh22dx)
Ouch!
somebody needs to learn to shift...
Old Sep 26, 2002 | 08:45 AM
YodaIsGod
Guest
Posts: n/a
Default Re: Please explain "valve float" (jweller)
I guess valve float cannot be achieved with an auto tranny?!
Old Sep 26, 2002 | 08:50 AM
Chris's Avatar
UH OH!
Valve float can be achieved on any overhead cam motor (maybe not limited to)
Usually caused by over-revving. Springs are just curled up metal.. make them move too fast and they turn to "jelly" and stop being springs. More like a piece of metal, thats really hot!
(hence the need for hydraulic lifters in F1.. 14,000 RPM is impossible for a spring)
Dont worry, the IS300 is still under warranty!
Old Sep 26, 2002 | 09:43 AM
falcongsr's Avatar
What is this crap?
Default Re: Please explain "valve float" (Chris)
i thought formula 1 were still opened by a traditional cam, but the valve was slammed shut with a pneumatic system, to get it out of the way before the piston occupies the same spot.
and they are running near 19,000rpm (according to the announcers at Monza last week)
State.of.Prime
Oct 17, 2010 01:43 PM
TURBL0W
Nov 9, 2005 01:17 AM
Arturbo
Feb 9, 2004 02:26 AM
Blown90hatcH
Nov 8, 2001 06:47 PM
