Which pistons combo shoud I use.
Old Jun 16, 2003 | 12:30 PM
ahki's Avatar
Default Which pistons combo shoud I use.
Bought a B18C6 off a guy who raced in the BTCC (British Touring Car Champioship) for £1000 yesterday,
took it apart and guess what I found, I called him to confirm.
The engine was originally built by Neil Brown Racing, who prepares the Honda TOCA Type R engines.
well, the cams are BTCC spec with Mardigras cam pulleys
but what came out of the block was quites interesting...
The pistons are Accralite F3 forged pistons with two rings and Arrow Con Rods,
unfortunately It has a missing Crank, but was advised that all I need is a B18C crank and it will do the job. The displacement will be 2.0L
however I have some new piston and conrods, so what do I use?
from left to right. Accralite F3 piston with Arrow Rods, Spoon P73 Piston with Spoon P73 rods and JE 12.5:1 with Crower Rods.
any help appreciated. thank in advance.
more pictures here http://www.b-factory.co.uk/htech/
Modified by ahki at 11:50 AM 6/17/2003
Old Jun 16, 2003 | 12:47 PM
poison's Avatar
Default Re: Which pistons combo shoud I use. (ahki)
What do you plan on doing with the motor?
I would advise to use the P73 pistons with Spoon rods, or the JE combo.
HTH.
Old Jun 16, 2003 | 01:01 PM
ahki's Avatar
Default Re: Which pistons combo shoud I use. (poison)
I'm thinking of building a NA engine for trackday use. as spare to my existing engine.
Old Jun 16, 2003 | 03:22 PM
GZERO's Avatar
in the arrow rod, i see the bearing journal with a dark like color on the outside, this might be caused by a spun bearing, but it might also be part of the casting.
Does it looks uniformly? does the other rods have it?
BTW: which of the three is the lightest?
Old Jun 17, 2003 | 02:54 AM
ahki's Avatar
Default Re: Which pistons combo shoud I use. (GZERO)
The bearing had burnt up and the crank is damaged, however the they look fine, so the Rods can still be used.
i call Neil Brown racing today and they want GBP6000 - GBP7000 for a engine rebuild!!! that's $10000 - $12000!
georgi
12
Aug 15, 2014 10:31 PM
anjgsr
Mar 10, 2010 09:48 AM
thumper64
Nov 4, 2009 11:58 AM
x2gold
Jun 1, 2003 04:08 PM
