piston question
Old Jul 2, 2002 | 02:56 AM
10seconds's Avatar
Honda-Tech User
Default piston question
Can someone please explain this to me. If you have a JDM ITR motor and you put CTR pistons in it it will give you more compression. This doesnt make since to me cause the JDM ITR already has a higher compression then the CTR motor. I know it does make more compression but I just want to know why.
Steve
Old Jul 2, 2002 | 05:05 AM
g2teg's Avatar
Default Re: piston question (jdmimports79)
CTR pistons have a higher dome on top. That compresses the air/fuel into a smaller space creating a bigger bang.
Old Jul 2, 2002 | 06:16 AM
10seconds's Avatar
Honda-Tech User
Man its really cool to know that. IMO. So if I put the CTR piston in a B20z block would that also give me a higher compression, or would I have a valve clearance issue. If so what would you have to do to put the CTR piston in a B20z block.
Steve
Old Jul 2, 2002 | 08:20 AM
sgT's Avatar
sgT
you cant put ctr pistons in a b20 block. B20 bore is 84mm, ctr is 81mm
Old Jul 2, 2002 | 09:37 AM
10seconds's Avatar
Honda-Tech User
Default Re: piston question (sgT)
OH yeah WTF was I thinking sorry I was tired and just got off work. God im a ****** idiot for not remembering that.
Steve
Old Jul 2, 2002 | 01:36 PM
qbsi's Avatar
would a stock bore ctr pistons fit ok on a 00 si?
i heard you have to mill 1mm of each side of the rod. if thats true, where can i take it to get it done and how much does it usually cost?
thnx. guys
Old Jul 3, 2002 | 12:22 AM
Katman's Avatar
Steve
The stroke also adds to the compression ratio.
That's why the JDM ITR is 11.1. Even though it has a lower piston dome than a CTR piston, the 1.8L stroke compensates, along with the P73-A00 piston creates an 11.1 cr.
The B16B is 1.6L with a higher dome of course puts out 10.8cr. It being 1600cc looses the compression ratio battle, because it's not compressing as much air & fuel as the 1800cc ITR engine.
hth.
[Modified by Katman, 1:23 AM 7/3/2002]
ntensehonda
Dec 30, 2005 01:11 AM
shomershavis
11
Sep 4, 2004 10:19 AM
00BlackDc2
Feb 22, 2004 12:13 AM
duRritztiNy
35
May 16, 2003 10:36 PM
zentraedityper
Jun 16, 2001 04:32 PM
