piston pin removal
Old Oct 15, 2008 | 07:01 PM
I AM WEASEL's Avatar
Default piston pin removal
I know that oem pistons need to be pressed off of the rods, but is there some specific tool that is needed for a hydraulic press to press them off?
Old Oct 15, 2008 | 07:28 PM
solturbob16sol's Avatar
* B A N N E D *
Default Re: piston pin removal (I AM WEASEL)
yes but i have seen people do it with a hammer and torch
Old Oct 15, 2008 | 07:31 PM
Default Re: piston pin removal (solturbob16sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solturbob16sol &raquo;</TD></TR><TR><TD CLASS="quote">yes but i have seen people do it with a hammer and torch </TD></TR></TABLE>
I would rather press them off, getting them off with a hammer and torch seams a little to me.
Anyone have a link to a place where I can get a piston pin tool for a hydraulic press?
Old Oct 16, 2008 | 04:35 AM
NJIN BUILDR's Avatar
Most any automotive machine shop should be able to remove them.Goodson or Sunnen should have the pieces if you have access to a press.I think Acura also has the adapters.Understand the pistons will most likely be junk after removal.
Old Oct 16, 2008 | 07:46 PM
srmofo's Avatar
Default Re: piston pin removal (NJIN BUILDR)
you might have better luck if you search for wrist pin tool, honestly if you are planning on reusing any of that stuff, just pay a machine shop to do it. its proly cheaper than the press die anyways.
B18aHatch
Apr 7, 2014 07:07 PM
paulITR
Nov 9, 2007 10:47 AM
flat-blk-HB
Mar 11, 2005 07:52 PM
95 integra
Apr 9, 2004 01:31 AM
Civic
Sep 21, 2003 08:45 PM
