Peak and hold injectors with P30 Ecu............is this possible??
Old Sep 22, 2003 | 02:03 PM
turboxsi's Avatar
Default Peak and hold injectors with P30 Ecu............is this possible??
Its just like the title says. I am currently running Peak and hold injectors on my 1st gen b16 with a 92-95 (del sol) P30 Ecu all in a '93 teg. I'm sure I don't have a resistor box, like I heard you need for Peak and hold injectors (all the y/b wires coming from each injector plug all go to a plug that just dead ends by the drive side shock tower). And from what i've read in my search 92-95 Ecu's can only run saturated injectors, but i seem to be running fine...is this possible or am i just overlooking something?? I realize this is a lot but i have done a search and really haven't gotten an answer.....Please help!!!
Old Sep 22, 2003 | 02:24 PM
turboxsi's Avatar
Default Re: Peak and hold injectors with P30 Ecu............is this possible?? (turboxsi)
bump
Old Sep 22, 2003 | 03:41 PM
turboxsi's Avatar
anyone............???
Old Sep 22, 2003 | 05:46 PM
Kusai.Nihonjin.Desu's Avatar
Bump for my homey b/c I don't have a clue about this subject either.
Old Sep 22, 2003 | 06:12 PM
D3LSLO's Avatar
bump cause id like to know
Old Sep 22, 2003 | 11:04 PM
KS-R's Avatar
Are you sure you're running 1st gen B16 injectors? What colour are the injector clips? creamy yellow or gray? What about your injector tips? Did the injectors plug right into your stock harness?
Old Sep 23, 2003 | 08:42 PM
turboxsi's Avatar
Default Re: Peak and hold injectors with P30 Ecu............is this possible?? (KS-R)
Im running injectors from a b17 I believe, not 100% sure (got them from my mechanic, 2.5 ohms=Peak and hold), and my clips are gray. I just had to alter the injector very little to fit my clips. But all I want to know it how im running peak and hold injectors on my P30 obd1 Del sol ECU......anyone???
Old Sep 24, 2003 | 08:03 AM
turboxsi's Avatar
bump................
Old Sep 24, 2003 | 11:49 AM
bogus_ek's Avatar
don't take your chances... run the resistor box. it's not that expensive... find them on ebay all the time for $50... and not too hard to install.
Old Sep 26, 2003 | 12:55 AM
turboxsi's Avatar
Default Re: Peak and hold injectors with P30 Ecu............is this possible?? (bogus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogus &raquo;</TD></TR><TR><TD CLASS="quote">don't take your chances... run the resistor box. it's not that expensive... find them on ebay all the time for $50... and not too hard to install. </TD></TR></TABLE>
My car has been running this setup for 2 1/2 years with no problems (no resistor box). I never thought to look until now, because I needed new injectors and I noticed the peak and hold; and P30 ecu combo. I didn't think it was correct, so i want to know if its possible though this thread....??
Old Sep 26, 2003 | 06:24 AM
turboxsi's Avatar
bump
Old Sep 26, 2003 | 08:52 AM
Davep's Avatar
Did you measure the resistance of the injectors yourself?
Old Sep 28, 2003 | 03:43 PM
turboxsi's Avatar
Default Re: Peak and hold injectors with P30 Ecu............is this possible?? (Davep)
yeah i measured the resistance myself. I have two sets of Peak and HOld (2-3 ohms of resistance) injectors and one saturated set (11-13 ohms of resistance.). So its very easy to tell the difference.
Old Sep 29, 2003 | 05:41 PM
turboxsi's Avatar
bump...................................
Old Oct 5, 2003 | 02:59 PM
turboxsi's Avatar
Some has got to know.................bump
Old Oct 6, 2003 | 04:16 PM
Where're the honda-tech gurus?
Old Oct 7, 2003 | 01:43 PM
turboxsi's Avatar
Default Re: Peak and hold injectors with P30 Ecu............is this possible?? (Nihonjin)
Bump
Old Oct 9, 2003 | 03:22 PM
Still bumpin' this dag'on thread.
thai-lorn
Apr 27, 2007 04:52 PM
a1320addict
Jan 25, 2007 06:50 PM
street dreams
Jan 5, 2004 05:18 PM
turboxsi
Oct 7, 2003 01:44 PM
UncleBen'sRacing
May 20, 2003 03:17 AM
