p740 engine code trouble
Old Sep 25, 2013 | 02:49 AM
Mr. Salon's Avatar
Default p740 engine code trouble
I have a 2000 honda civic ex that I have recently replaced the motor. The car runs great but my engine light came a week later. The code that comes up is p740. I used vavoline transmisson fluid that stated it was good for imports. I have a new torque converter and I have also replaced the vavoline trani fluid with honda trani fluid. My question is, what can I do to fix this. I'm not a mechanic but I can turn a bolt or two. Any help is welcome
Old Sep 26, 2013 | 06:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: p740 engine code trouble
P740 is Lock Up Control System and unless you have the tools it is not something you can do yourself.
The first test is to check line pressure.
About the only thing you can do is toss parts at it, replace the Lock Up Control Solenoid Valve A/B Assembly and see if that solves your problem, however, tossing parts at a problem is an expensive way to troubleshoot a problem. 94
Old Oct 3, 2022 | 03:11 PM
gothicsunrader's Avatar
Did you ever solve this problem? I’ve got the same thing on an 02 Civic that got a new tranny at 79k miles now at 160k. No symptoms. Just throws the code. Runs great. Thx.
2006 Honda_Odys
Aug 11, 2018 05:14 PM
hondagirl9589
Transmission & Drivetrain
Feb 25, 2014 08:27 PM
jeremy8886
Dec 7, 2005 06:54 PM
kiwirob
Acura TL, RL & ZDX
Jul 5, 2002 10:20 AM
