P28 ecu questions
Old Feb 3, 2002 | 06:35 PM
HOND PWR's Avatar
Default P28 ecu questions
I have a 94 gsr motor with Skunk2 intake,US ITR pistons,CTR cams,Header and Mugen thinlayer head gasket. I was going to get my GSR p72 ecu reprogramed but was told a chipped p28 was better. The question is are all p28 ecu's the same? I would guess all 5spd 92-95 civic ex's came with that ecu am I right some one please help.
Old Feb 3, 2002 | 08:17 PM
Halo's Avatar
Default Re: P28 ecu questions (HOND PWR)
I am kind of in the same dillema as you, except I have a crvtec. I hear mixed things.Not sure what your compression is but my whole decision will be based on not detonating. I have heard that for high compression removed knock sensor(P28) is more likely to detonate than the P72(w/knock sensor). As for the P28 I believe all 92-95 civic ex/si's are the P28. I have both in my hand right now trying to decide which one is best. Whats the octane out in va?
Old Feb 3, 2002 | 09:12 PM
FSTASNTZ's Avatar
Honestly, since it has knock sensor capabilities, I would stick with the P72 and get it reprogramed. It is going to cost about the same as reprograming the P28.
Jason
Old Feb 4, 2002 | 03:03 AM
HOND PWR's Avatar
Default Re: P28 ecu questions (Halo)
I can buy 93 octane, so far my car runs fine on that. I was considering the p28 for 2 reasons. 1. The p72 cost too much to replace if I don't like the new program. 2. I have a ls/vtec that I was was going to put together so I thought i could use it for that(no need to buy a knock sensor).
Old Feb 4, 2002 | 04:01 AM
sloaccord's Avatar
New User
Default Re: P28 ecu questions (FSTASNTZ)
just so you know, the knock sensor on a p72 no longer reads after about 4 or 5 thousand rpms. it isnt designed as a high-rpm motor saver, it's designed to read crappy gas and compensate at low rpms. . .
Old Feb 4, 2002 | 01:05 PM
HOND PWR's Avatar
Default Re: P28 ecu questions (sloaccord)
I did not know that it only reads under 5 thousand. I am putting a ls/vtec together out of spareparts and I thought if I get a p28 (cheap) chipped to work better or the same as a p72(expensive) it might save me some money. Thanks for the info.
froogle29
Jul 16, 2008 02:00 PM
CRX_RR
Feb 21, 2008 04:20 PM
EJ1_203
Jul 23, 2005 04:48 AM
SETI20
Aug 17, 2004 11:57 AM
IdotheSHOCKER
May 30, 2002 09:42 AM
