P28 AUTO to MAN ECU, Questions.
Old Nov 14, 2004 | 01:45 PM
D3U1LT's Avatar
Default P28 AUTO to MAN ECU, Questions.
I am in the process of convertion my P28 AUTO ECU to MAN, but I have a couple questions:
1) What should I use to remove the resistors (RP17/18)
2)When soldering the jumper (speaker wire) I heard that you have to be grounded to the computer or something or the other crystals will get different feedback. Is this true?
3) If number 2 is true then how is it that you ground the computer so you dont get the feedback.
Thanks in advance for any information given.
Old Nov 14, 2004 | 02:15 PM
mmuller's Avatar
Mad Scientist
Default Re: P28 AUTO to MAN ECU, Questions. (EJ1Racing.tk)
to take the resistor out you can use desodering braid or a desodering gun.
you need to ground yourself so that static dont zap the electronic components
Old Nov 14, 2004 | 02:51 PM
D3U1LT's Avatar
Default Re: P28 AUTO to MAN ECU, Questions. (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">to take the resistor out you can use desodering braid or a desodering gun.
you need to ground yourself so that static dont zap the electronic components</TD></TR></TABLE>
How do you ground yourself?
When soldering the jumper where do you solder it. Do you solder the wire where the green goes or the red goes?
Old Nov 14, 2004 | 03:10 PM
mmuller's Avatar
Mad Scientist
you remove RP17 and RP18 and then replace RP18 with a jumper wire
edit: there is kits to ground yourself
Old Nov 14, 2004 | 03:12 PM
D3U1LT's Avatar
ok, i see now! thanks.
Old Nov 14, 2004 | 03:13 PM
D3U1LT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">edit: there is kits to ground yourself</TD></TR></TABLE>
Do you still have to ground yourself if the ECU isnt plugged in?
Old Nov 14, 2004 | 03:34 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1Racing.tk &raquo;</TD></TR><TR><TD CLASS="quote">
Do you still have to ground yourself if the ECU isnt plugged in?</TD></TR></TABLE>
yes
Old Nov 14, 2004 | 06:50 PM
D3U1LT's Avatar
is there anything else i should know before i do this?
thanks for everything!
Old Nov 16, 2004 | 06:23 PM
99lsvtecauto's Avatar
got 2 hondata website they tell u how 2 do in the tech section with a good diagram
jordan2305
Nov 3, 2007 04:19 PM
donaldmejr
Aug 13, 2007 07:29 PM
badblackhatch
Jun 27, 2007 04:40 PM
D3U1LT
Nov 14, 2004 01:19 PM
gloryhog
Aug 30, 2003 06:05 AM
