Help with h22 swap in Eg civic !!!!
Old 11-13-2009, 07:06 AM
integraluva04's Avatar
Default Help with h22 swap in Eg civic !!!!
so im a h22 swap in myfriend eg civic. i was wondering is it possible to use his old gsr harness on the h22 without having to swap or splice anything? if anyone can help me please let me know.
Old 11-14-2009, 10:33 PM
pArAdOxsqUArE's Avatar
Default Re: Help with h22 swap in Eg civic !!!!
i would either match up both engine harness or just start plugging everything in... rmb the alternator is on the front of the H22 so basically you will have to stretch wires and what not.
GL with everything.. looking to go H also... my CTR cost to much to finish
Old 11-18-2009, 11:08 PM
H_Bliss's Avatar
Let me check my friends EG and let you know, he has the H22 set up in his.
Old 11-19-2009, 05:03 AM
twentyhurtz's Avatar
my friend put a h22 in his eg hatch and said he used a modified z6 harness
Old 11-22-2009, 09:59 AM
so all i have to do it stretch the harness for the alternator? and also the car had a gsr swap in it already so i can use that harness and just strech the wires for the alternator....
Old 11-22-2009, 02:03 PM
SolAssassin's Avatar
it all depends on the ecu you are using. are you going to wire up your secondaries (IABs)? knock sensor? egr? are you going with a P28? if so, are you adding IABs to the ecu?
Old 11-22-2009, 02:06 PM
i am going to use the stock h22 ecu that came with the obd1 swap
Old 11-22-2009, 04:52 PM
when i first did my swap, i stayed with the stock ecu. you are going to have to wire up IABs, knock sensor, and EGR (and it has to work) if you don't want to look at a check engine light. the gsr harness might work but you will need to add wires for EGR
Old 11-22-2009, 04:56 PM
you're better off getting a gsr computer and chipping it out to work with the h22. that ecu has everything you need minus the EGR. the p13 is not tunable, at all (and you won't be able to go over 112 mph). i put my p28 back in myself and added IABs and a good tune
Old 11-22-2009, 10:44 PM
do i have to wire up the egr and the iabs? and iabs stands for inatake..... also have any pictures of it like the wires for the iabs and egr?
Old 03-18-2010, 09:01 AM
what kind of axles are needed?
Old 03-18-2010, 07:09 PM
Kyle R's Avatar
You mentioned that you're trying to resuse your GSR harness. Did you wire up the IAB's for the GSR engine? What ECU?
Old 03-22-2010, 06:35 AM
yea i reused the gsr harness. iab's? and the ecu was a chipped p28 ....
Old 03-25-2010, 04:43 PM
help hot damn
Old 03-26-2010, 06:14 AM
hashaam81's Avatar
You can re use the harness with some slight modifications.
Old 04-04-2010, 09:30 AM
axle help people
A-Star
12-02-2008 10:32 AM
teefunk01
Northeast (Sales)
10-21-2008 04:40 PM
dc2vu
12-07-2006 07:07 PM
Quick Reply: Help with h22 swap in Eg civic !!!!
