Overheating problems help!!!
Old Feb 8, 2007 | 10:15 PM
Dj^BaNNeD's Avatar
Default Overheating problems help!!!
Hello
I know that there are alot of posts on this, but i havent found what ive been looking for. Lately my car has been overheating. I put coolant and water in. Its fine after about an hour or less. But after i drive it i see coolant all on the ground (from the same spot as the resivor. But theres still alot in the resivor. Afterwards theres steam. The fan will come on afterwards. Then the radiator is empty too.
Oh and another thing, the car use to be fine when driving but it start to rise when im at a stoplight. But now it overheats when im driving too.
Anyone know what it could be?!?!?!?
Thanks
Modified by Dj^BaNNeD at 12:28 AM 2/9/2007
Old Feb 8, 2007 | 11:57 PM
iheartjayDem's Avatar
Default Re: Overheating problems help!!! (Dj^BaNNeD)
check to see if you head gasket is blown.
that happened on my friends d16.
when the car is COLD open the radiator cap and start the car.
if you see bubbles that means your head gasket is blown and the exhaust is getting in the cooling system
Old Feb 9, 2007 | 05:32 AM
KLiK's Avatar
you head gasket is thorn!!
so the pressure from the cilinders pushes the pressure in the water coolant system...and that makes the radiator cap open and spiting the water coolant from the reservoir...
get that fixed URGENTLY!
Old Feb 9, 2007 | 08:06 AM
Dj^BaNNeD's Avatar
Default Re: Overheating problems help!!! (KLiK)
But wouldnt you see a pile of white smoke coming from the exhaust???
Old Feb 9, 2007 | 10:30 AM
Dj^BaNNeD's Avatar
Didi some research.
Just checked the upper and lower hoses. The top one is hot but the lower hose is cold. It also leaks out coolant as i just put some in. And the car idles wierd.
Will a blown headgasket affect performance a well???
Cause i test drove my car around the block, runs fine.
Old Feb 10, 2007 | 10:18 AM
i would think it should.
check your thermostat?
flush your cooling system?
does your fan engague properly?
Old Feb 10, 2007 | 04:22 PM
Dj^BaNNeD's Avatar
Update....
It was my thermostat and my radiator is busted.!!!
jonlovesuti
May 18, 2010 08:39 PM
marvinmark21
Jan 14, 2008 04:21 PM
93eh2hatch
27
Dec 19, 2007 03:02 AM
scoobyghost
17
Jun 14, 2004 11:17 AM
